FOR SALE: Gustard X20 DAC SOLD
0 Members and 1 Guest are viewing this topic. Read 433 times.
jbetanc
« on: 18 Jan 2025, 06:39 am »
[[/b][/b]
In mint condition, ready to plug and play, PPF, shipping is included $380 in USA or local pick up in So. Cal area
Product Features:
• DAC-X20 core chip uses two ES9018, left and right channels for each one.
• the first use of adaptive technology and asynchronous master clock master clock technology, two clock mode can be freely selected.
• Full interface supports DSD decoding. USB support DSD hardware solution, Coaxial Optical AES / EBU support DOP decoding, which can be accessed several broadcast SACD listening to music. Full interface supports 24Bit 192khz (USB 32B 384K).
• using CPLD programmable logic device. MESNAC ES9018.
• 3-speed gain, volume can be adjusted, a total of 100 stalls adjustable volume attenuation from 0 to -99DB.
• USB sub card using XMOS program, PCM highest support 32B 384khz, DSD up to DSD128.
• six kinds of input methods: IIS fiber `BNC coaxial port` AES / EBU`USB, through the key switch.
• Adopt TFT LCD display, adjustable contrast
• power supply with two O-type transformers, digital and analog independent power supply, and the use of discrete components regulation.
• Fully balanced analog line discrete components. Unbalanced RCA output simultaneously.
« Last Edit: 28 Jan 2025, 06:06 am by jbetanc »
