0 Members and 1 Guest are viewing this topic. Read 4139 times.
I owned the Tube Box S2 and it was fine for what it was, but there is better than the ProJect stuff for equal or less money.Tubes4HiFi have several phono options. The PH14 at $500 assembled in a custom chassis and ready to go would beat the DS series. Plus if you felt like upgrading parts, everything is thru hole mounted.http://www.tubes4hifi.com/PH14.htmIf you felt like really going wild, I have the PH16 that I hotrodded a bit farther than a standard kit and it blows away my friend's Parasound JC3 Jr.http://www.tubes4hifi.com/PH16.htm
I do get the SE vs Balanced route. Luckily there's cables for that thought. With the ProJect series that I've heard (and a few other high gain phono stages, the power supplies get pretty noisy. With this series in particular, anything above 40dB gain is noticable and 60+ was pretty gross by comparison. With those considerations, the Parasound would be the better choice.If you really felt like going all in on the tube route and accepting a SE to XLR cable lifestyle, the Don Sachs phono stage is something to look at. It's an upgraded PH16 and you can have a SUT built inside. That's the design upgrades I followed for my PH16 build and it is best of both worlds but most $$ option.
I love tubes, have owned many tube preamps but for anything needing more than 12db gain, I just stick with SS for superior THD + noise. It's not about the psu but the tubes themselves. You already have to contend with noise and distortion inherent to vinyl, why make it worse? I would pick the JC3 any day.
