Poly Fill, Black Hole 5 and No Rez Questions ..............
0 Members and 1 Guest are viewing this topic. Read 1497 times.
Cut-Throat
I assembled a pair of GR Research Paradox Ones about 20 years ago and Love them. I still can't get over how great they sound! I am currently getting a pair of XLS Encores built by Mike Lundy with Padauk Wood Cabinets and this prompted me to watch the videos of Danny Building them. When I got to the Poly Fill section, I had a WTF Moment!
A couple questions:
1.) When I assembled the Paradox Ones, I used a product called Black Hole 5 that Danny was recommending. I was wondering if either Product was superior? (Black Hole 5 or No Rez).
2.) The WTF moment came when I was watching the Poly Fill segment. When I lined my Paradox Ones with Black Hole 5, I had thought that was the replacement for Poly Fill, hence I never put any Poly Fill in my Paradox Ones.  Should I open them up now, and stuff the Poly Fill inside as Danny described in the Video?  How might that affect the Sound?
Danny Richie
Re: Poly Fill, Black Hole 5 and No Rez Questions ..............
« Reply #1 on: 24 Dec 2024, 11:49 pm »
A couple questions:
The development of No Rez came from early use of Blackhole 5.
Blackhole 5 was great and damping resonances, but sometimes I felt like it muffled up the mid-range. This was typically when it was completely lined with Blackhole 5. The suspended barrier layer was the cause.
When I first started developing No Rez (what I ended up calling it), I tried a ton of variations including lead layers, and different damping materials. Anytime a heavy barrier layer was used I got a more muffled vocal region. Pulling it out opened up the vocals, but bass levels were not as clear. I finally settled on a damper that was nearly twice as thick as the one used in Blackhole 5, but no barrier. That yielded the best sound.
You might want to try a little light polyfill or fiberglass insulation and hear what happens. There is no right or wrong answer.
Cut-Throat
« Reply #2 on: 25 Dec 2024, 06:19 pm »
OK, Thanks for your reply!  --- Since the Paradox Ones sound so good, I think I'll leave them alone for now. Until at least I get my XLS Encores this Spring. After I listen to them, I'll decide if the Paradox Ones need an 'upgrade'.....  :wink:
Danny Richie
« Reply #3 on: 27 Dec 2024, 12:39 am »
Sounds like a plan.
