Just wondering?
0 Members and 1 Guest are viewing this topic. Read 1633 times.
johnwoitalla
Just wondering?
« on: 24 Dec 2024, 05:39 pm »
It is 9:30am here. I made a post about 5 minutes ago, but it shows on the board here that it was 5:25pm when I posted? Do I have to make some change in my settings on my end in order for the correct time to register?
« Last Edit: 25 Dec 2024, 04:33 pm by johnwoitalla »
Danny Richie
Re: Just wondering?
« Reply #1 on: 24 Dec 2024, 07:52 pm »
I have no idea.
You might post that comment in the notices and support circle.
johnwoitalla
Re: Just wondering?
« Reply #2 on: 24 Dec 2024, 09:10 pm »
I have no idea.
Will do, and Merry Christmas.
nlitworld
Re: Just wondering?
« Reply #3 on: 24 Dec 2024, 09:25 pm »
Go to your profile, then on the far left side click Look & Layout and there's an option for Time Offset. Click Auto Detect then at the bottom click Change Profile (save).
johnwoitalla
Re: Just wondering?
« Reply #4 on: 25 Dec 2024, 04:34 pm »
Gracias
johnwoitalla
Re: Just wondering?
« Reply #5 on: 26 Dec 2024, 04:43 pm »
I did as you suggested and it solved the problem.
