Crosssover point
0 Members and 1 Guest are viewing this topic. Read 2282 times.
JRNII
Crosssover point
« on: 18 Dec 2024, 08:54 pm »
What is the best crossover point for a T26SG tweeter in a 3 way design?
JRNII
Re: Crosssover point
« Reply #1 on: 18 Dec 2024, 08:57 pm »
Looking for the FRD/ZMA data file but can't find it.
Hobbsmeerkat
« Reply #2 on: 18 Dec 2024, 09:28 pm »
We recommend crossing the T26 in the 1700-2000 Hz Range in either 2 or 3 ways speakers, but it really depends on the application.
We don't have any FRD or ZMA files for our drivers, as the driver's response will change quite a lot, depending on the baffle/cabinet you put the driver into.
JRNII
« Reply #3 on: 18 Dec 2024, 09:39 pm »
Thanks. 58 and working on first real speaker build.
JRNII
« Reply #4 on: 18 Dec 2024, 09:41 pm »
What microphone due you recommend to measure frequency response?
JRNII
« Reply #5 on: 18 Dec 2024, 09:49 pm »
After finishing the speakers i'm working on I'm thinking about the X-statik. Unless Danny comes out with the new speaker he mentions in his video's.
EdwardT
« Reply #6 on: 19 Dec 2024, 12:09 pm »
I have a set of X-Statik with maxed out crossovers in my listening room and they are better than any other speaker I’ve ever heard. I still really like my Encores but the X-Statik is a level above and then some.
« Reply #7 on: 19 Dec 2024, 06:09 pm »
What would be really cool would be the X-Static with a Neo3 tweeter.
corndog71
  • Some people call me Rob.
« Reply #8 on: 19 Dec 2024, 08:37 pm »
And even better than that would be if that Neo3 tweeter was open on the back.
Danny Richie
« Reply #9 on: 24 Dec 2024, 07:42 pm »
While we are at it, let's step up the mid-bass woofers to the M165NQ/16's, and then stack four open baffle woofers below.
Oh wait, we have that speaker. It is the NX-Otica.
corndog71
« Reply #10 on: 24 Dec 2024, 08:31 pm »
You’re missing the point, Danny.  X-Statiks have the lower cost mids and woofers which would be elevated with a OB neo3 tweeter.  The point is to have a step between X-Statiks and NX-Oticas.
« Last Edit: 24 Dec 2024, 10:34 pm by corndog71 »
« Reply #11 on: 24 Dec 2024, 08:54 pm »
True!  I never thought I’d see the Neo3 mated to any midrange driver except the M165NQ’s.  But then the NX Bravo happened and I thought the X-Static might now be an option.
On the other hand I can see that any business has to avoid ‘model creep’’.  It’s just not feasible to offer every variation of every option that is possible.
Danny Richie
« Reply #12 on: 24 Dec 2024, 11:42 pm »
I am afraid it will blur the lines between them, but I will consider it.
« Reply #13 on: 25 Dec 2024, 12:12 am »
Even though it would be a fun speaker, I have no intention of every building an X-Static, I am quite happy with the NX-Oticas and LineForces.
corndog71
« Reply #14 on: 25 Dec 2024, 02:42 am »
I’m pretty happy with all of my speakers too.  The Super7 are still my end game speakers.  I would love to get the Line Forces but they are too much trouble and expensive for me.
The X-Statiks are also great but the last time I listened to them they sounded a little muted.  I know the encore is a great tweeter but not right after hearing the Neo3.
I get the blurry lines.  I just thought it was a cool idea.
mzbrahce
« Reply #15 on: 26 Dec 2024, 08:33 pm »
Danny designed an X-Static with a Neo3 in 2006--the OB-5.  Check out the Archive section on the GR Research website. I have a pair and they are wonderful speakers.  It is taking Super Minis and a pair of Double Troubles to better them.
corndog71
« Reply #16 on: 26 Dec 2024, 10:22 pm »
Yeah, I’m sure those sound great.  Make the tweeter open baffle and they could be even better.  The only downside would be the baffle might need to be CNC cut.
Danny Richie
« Reply #17 on: 27 Dec 2024, 12:50 am »
That was an OB-5. It used the smaller M-130 sized woofers.
