SOLD - High Current Linear Power Supply DC5V 8A + DC12V 8A.
0 Members and 1 Guest are viewing this topic. Read 944 times.
mytubes211
  • Please no BS !!!
Hi, I'm selling very powerful 2 way high current Linear power supply for Audio DC5V 8A + DC12V 8A.........
Low voltage pressure difference. Large current heating less.
D25BS60 Schottky Rectifier Bridge, 4pcs P-MOS Transistors parallel Output.
Use OP Voltage Follow Circuit
Output voltage is Very stable.
Ultra-low noise, low Ripple.
On each power supply board with 4 PCS precise matched Power transistor IRF9Z34
Transformer power: 300VA Oxygen free copper Toroid Transformer
I will include two high quality 1.2m DC output cables but no power cable. Unit will be double boxed with lots of protective foam and plastic protection for the all corners. Shipping box will be 13x14x9 inches and around 18lb. Pickup is available or if needed I can deliver it in reasonable distance from 07922, NJ zip code.
I'm asking $200 plus shipping......Thanks
« Last Edit: 8 Jan 2025, 09:15 pm by mytubes211 »
mooncrikit
Re: High Current Linear Power Supply DC5V 8A + DC12V 8A
« Reply #1 on: 18 Dec 2024, 07:14 pm »
Can this be used with gear that is rated for lower amperage input like 5V, 2A or 12V, 3A? And what brand is it,? I am very interested if it will work effectively without damaging the periferal equipment with lower amperage ratings. And what was/is the MSRP on it? Thanx, Jeff
mytubes211
  • Please no BS !!!
« Reply #2 on: 18 Dec 2024, 07:42 pm »
Hi Jeff, yes and my unit pretty unique with 8A. Usually, you can get only up to like 3.5A. It's a lot, but it's always good to having more like less. It's possible, because my have huge and overbuilt 300V Transformer. Every equipment will take only as much amps he needs. Good thing is that you have ready more and extra. I was running LAN splitter 12V & 1.2A, Fosi ZD3 DAC 12V & 1.5A and LAN adapters to Coax cable with 5V & 0.5A with absolutely no issues.
mooncrikit
« Reply #3 on: 18 Dec 2024, 08:39 pm »
Thanx for the clarification.. Now kindly answer two other questions as to what brand/model number is it and what is the MSRP (Retail) price of this power supply...Thanx once more, Jeff
mytubes211
  • Please no BS !!!
« Reply #4 on: 18 Dec 2024, 09:00 pm »
Zero@Zone very good and reliable company, on unit box it's mark as Z-19 model number. I sending you link to eBay where I originally ordered the unit...... right now it's on sale $230 + $78 for shipping
mooncrikit
« Reply #5 on: 18 Dec 2024, 10:23 pm »
Can't seem to find it on eBay..please follow through with the link to the eBay listing...Thanx once more, Jeff
mytubes211
  • Please no BS !!!
« Reply #6 on: 18 Dec 2024, 10:31 pm »
Funny, me too.....I guess they out of stock as right now. Well, unit is legit, I'm stend up guy who stands behind his words. I guess you have to go with that for now. Where are you located? Can you picked up unit? This way you can see it for your self.....
mooncrikit
« Reply #7 on: 19 Dec 2024, 01:52 am »
Yea, a lotta weird that their website doesn't mention this unit and after closely examining its perceived dimensions, they are extremely huge for where I need to park it so at this point, I am going to pass..apologize but congratulate you for your efforts brought forth...good luck with the sale, should be a slam-a-jamma for the lucky next owner...Kindest regards, Jeff
mytubes211
  • Please no BS !!!
« Reply #8 on: 19 Dec 2024, 02:22 am »
No problem Jeff, I will keep looking on eBay and they may pop out back for sale. This is almost like costume build but I can tell you that these guys know what they doing. You can see a lot smaller units with only 50V-120V R-Core Transformer, O-Ring Transformer with 5/7/9/12/15/19V output and only top 3.5A starting $70 + shipping......
eBay online store calls GZLOZONE
Cheers, Richie
mytubes211
  • Please no BS !!!
« Reply #9 on: 27 Dec 2024, 07:25 pm »
...... now available for biting on Audiogon.......
« Last Edit: 5 Jan 2025, 04:29 am by mytubes211 »
mytubes211
  • Please no BS !!!
« Reply #10 on: 5 Jan 2025, 04:28 am »
!!! SOLD !!!
