No-Rez expiration date?
0 Members and 1 Guest are viewing this topic. Read 3998 times.
Neccros
« on: 8 Dec 2024, 05:02 pm »
I bought the upgrades roughly 5+ years ago to upgrade my AV123 X-LS speakers and after dealing with depression and other life issues, I found a friend willing to help me upgrade my speakers.
I got No-Rez and its been sitting in a box for the whole time and wanted to know, does it change or lose its ability to stick to the inside of the cabinet?? Also is it worth tossing it and buying the new version?
Re: No-Rez expiration date?
« Reply #1 on: 8 Dec 2024, 05:38 pm »
You could verify the glue current situation, if bad you could add a new glue layer IMO.
Danny Richie
« Reply #2 on: 24 Dec 2024, 07:20 pm »
It will stick.
Neccros
« Reply #3 on: 24 Dec 2024, 07:41 pm »
Also do I need some poly fill as well as the No Rez?
Danny Richie
« Reply #4 on: 24 Dec 2024, 07:42 pm »
You can still add some poly fill back in for fine tuning.
Neccros
« Reply #5 on: 24 Dec 2024, 07:49 pm »
I'm an amateur with speakers... what does the poly change?  And is it a huge difference between using it and not using it?
Danny Richie
« Reply #6 on: 24 Dec 2024, 08:02 pm »
It slows down the flow of air in the box and makes the box act as if it a larger. So fine tuning...
Neccros
« Reply #7 on: 24 Dec 2024, 08:04 pm »
I presume just use a little and dont pack it solid?
Appreciate all the help!
Danny Richie
« Reply #8 on: 24 Dec 2024, 08:20 pm »
Typically, yes.
Neccros
« Reply #9 on: 25 Dec 2024, 12:42 am »
Is there a specific brand or type of plot fill you recommend?
Danny Richie
« Reply #10 on: 25 Dec 2024, 05:27 pm »
I like fiberglass insulation best myself.
« Reply #11 on: 25 Dec 2024, 09:52 pm »
I like the brown car wood blanket 15mm.
The 5mm dont works, both are inexpensive.
It increase the bass under 250Hz and decrease the treble.
Danny do you could test it and inform us your opinion ?
« Reply #12 on: 25 Dec 2024, 09:56 pm »
The blanket is too thick, IME.  You really want something way more fluffy.
« Reply #13 on: 25 Dec 2024, 10:46 pm »
The image above show the 5mm that is thin, but it dont up the bass.
Neccros
« Reply #14 on: 26 Dec 2024, 04:18 am »
Is this sold on Amazon?  If so what do I search for?
Danny Richie
« Reply #15 on: 27 Dec 2024, 12:41 am »
Fiberglass insulation is at any hardware store like Lowe's or Home Depot. You can even find a spare handful of it pretty easily in your attic.
Neccros
« Reply #16 on: 27 Dec 2024, 12:45 am »
We rent this house and I wont do it... LOL   If I can get a brand or a link to an example, I will look for some from a friend or buy some worst case
Danny Richie
« Reply #17 on: 27 Dec 2024, 12:51 am »
It is only sold in large rolls. You won't need much, some just use a little polyfill. You can get polyfill just about anywhere too.
Neccros
« Reply #18 on: 27 Dec 2024, 12:54 am »
I might have a friend or two with some extra.
BrandonB
« Reply #19 on: 27 Dec 2024, 11:28 pm »
I am about to apply no-rez on some ottica's what is the best tool to cut it for nice looking edges?  Can it be sanded on the edges to Get a perfect look?  I am thinking of the curves.
