0 Members and 1 Guest are viewing this topic. Read 8969 times.
Are you sure about those calculations? 259kW-hr for a month is 259,000watts-hr/30 days/(24hours/day)=about 360 watts. Each one is 180 watts with no signal? My Jeff Rowland is about 120watts, for two channels. Also, .69/kw-hr is obscene! I thought CT was high at .15/kw-hr!
That's a lot of power. In Arizona, we had people tell us not to go class A because of the heat generated by these amps. If you have 360W being burnt in standby, that's a ton of heat being generated. In CT, it wouldn't be bad except for one-two months; but in AZ, it'd be bad for 9-10 months out of the year.
Then my Son (which is 1/2 the monobloc pair) should cost almost $90 a month extra???My whole electric bill is around $90 - $100 a month
My electrical bills are close to $150-200 or higher a month...
Quote from: John CaslerThen my Son (which is 1/2 the monobloc pair) should cost almost $90 a month extra???My whole electric bill is around $90 - $100 a monththat's probably becuz you never use your lights! your entire electric bill goes towards powering your audio gear! in the many times i've been to your place, i don't think i ever recall your lights being turned on. isn't that why you've got a bunch of those mini maglites laying around?
Lights?
John Casler is Lillian Muller's personal trainer (do a Google if you don't know this lady). By all reports the woman positively glows in the dark, no lighting needed!
Yup, talking to James each monoblock consumes 180watts at idle, also verified by my fluke clamp meter. Heck my now sold, Dehavilland monoblocks would consume 400W each at idle for a 30W amp. Although nothing like my woodworking machine and collector that takes nearly 13KW to run. The penalty for high electrical usage is insane in Orange County. My electrical bills are close to $150-200 or higher a month, and consuming more electricity means an even higher penalty rate. At least my gasoline bills are minor since I mainly work from home or at the airport or some other city.
Quote from: Brian CheneyJohn Casler is Lillian Muller's personal trainer (do a Google if you don't know this lady). By all reports the woman positively glows in the dark, no lighting needed!
ekovalsky,Have you thought of X10? I use this to turn on and off lights (now, only in my HT; before, throughout my house). You can set up a system you can operate from any room in the house. However, it does add some noise to the wiring, but the noise is only generated during commands, which are of short duration. And AZ is some of the cheapest electricity in the country.
