Audio Module's 10th Anniversary
0 Members and 1 Guest are viewing this topic. Read 3565 times.
Mary
  • AVA Associate
David A
Re: Audio Module's 10th Anniversary
« Reply #1 on: 25 Nov 2024, 04:26 pm »
 :thumb:
peter4jc
  • AVA DVA-M225's & Fet Valve CFR
« Reply #2 on: 25 Nov 2024, 05:27 pm »
I didn't versteh any of it, but it still fascinating to read, and to know a little about the design and capability that goes into AVA's excellent products.  Thanks Mary, Mithat, etal!
Tone Depth
  • Music Lover
    • SRLPE Wheel Works
« Reply #3 on: 26 Nov 2024, 02:13 am »
Thanks, I've often wondered what the module looked like, but have never opened up my digital preamp to see. I'd love to see a similar article on the DAC chip circuit implementation, and how it's performance compares to other approaches.
AVASupport
« Reply #4 on: 26 Nov 2024, 04:39 am »
Mithat says he has slated a post about how the output stage is done in the DVA Digital Preamplifier, in case that's close enough.
AllanS
« Reply #5 on: 26 Nov 2024, 11:51 am »
Many thanks! The technical stuff I’m gonna have to study so, at first read, the only thing I truly understood was the passion and commitment to excellence seemingly ingrained in the AVA culture.
More please, including a peek under the hood of the AVA digital pre!
TomBo
« Reply #6 on: 27 Nov 2024, 12:57 am »
The debate about which sounds better, digital or analogue? Mithat says "Bring it on"...
dlparker
  • Dave Parker - KC, MO
« Reply #7 on: 27 Nov 2024, 04:02 pm »
I'd like to add something of dubious value to this debate. As a tech/science/math dilettante I've said on multiple occasions something to the effect of "Yeah, analog may be better but calculus works".
Could folks out there who actually know what they're talking about tell me if I have any grasp whatsoever of the mechanics involved?
danielgk
  • AVA engineer/technicion
« Reply #8 on: 27 Nov 2024, 06:15 pm »
Here's my take:
Analog is never right.  It can be very, very, very close, but it is never right.  All the little noise/inductive effects, etc, etc only make it further from being right.
Digital is never wrong.  Unless the environment becomes so bad that the pulses can't get through and then everything collapses (catastrophic failure).  It is quite easy to build a digital widget in a bad environment that works perfectly.  It is almost impossible to build an analog widget in a bad environment that works at all, let alone works well.
Dan
dlparker
« Reply #9 on: 27 Nov 2024, 08:07 pm »
Here's my take:
Dan
Okay, let me see if I can further confuse myself. Assuming the data can be measured at all, digital is always right because it specifies an exact measure of a discrete data point at an exact point in time, whereas analog...
Okay. Never mind. I think I'll just try to say "digital widget" really fast three times in a row and then go listen to some Erik Satie.
"You don't think I'm crazy, do I?"
