SOLD: Pro-ject RPM 1.3 Genie turntable
0 Members and 1 Guest are viewing this topic. Read 727 times.
jbetanc
« on: 21 Nov 2024, 06:45 pm »
In great condition, includes dust cover, felt record pad, power for motor, 2 belts, and Oyster Cartridge . Can demo, pick up only in So. Ca. area
$280.00
MDF plinth with an isolated motor assembly optimized for low noise and speed stability..
• Fitted Cartridge: Oyster
• Amplifier Connection: MM-Input
• Nominal Speeds: 33 / 45 rpm
• Motor Completely Decoupled
• RCA Phono Jacks
• S Shaped Pro-Ject 8.6S (8.6") Tonearm with Carbon Fiber Armtube
• Overhang: 19mm
• Downforce Range: 10 - 30mN
• Speed Variance: ±0.8%
• Wow & Flutter: ±0.15%
• Signal-to-Noise: -70dB
• Power Supply: Outboard Power Supply
• Output Voltage: 12V / 200mA AC
• Power Consumption: 2W
• Dimensions (WHD): 15 x 4.5 x 13.8 in., 380 x 115 x 350 mm
• Weight: 7.3 lbs., 3.3 kg
Dimensions: 11.5 cm (H): 38 cm (W): 35 cm (D)
« Last Edit: 18 Apr 2025, 09:19 pm by jbetanc »
jbetanc
Re: For Sale: Pro-ject RPM 1.3 Genie turntable
« Reply #1 on: 27 Nov 2024, 04:28 pm »
price drop, great for second setup
jbetanc
« Reply #2 on: 6 Dec 2024, 01:20 am »
lower price bump
jbetanc
« Reply #3 on: 18 Dec 2024, 08:37 pm »
price drop bump  :wink:
edoggrc51
« Reply #4 on: 10 Mar 2025, 06:55 am »
Still available? Where in SoCal are you?
jbetanc
« Reply #5 on: 10 Mar 2025, 08:01 am »
Hi, still for sale, I'm in Lake Forest, by Irvine area.
edoggrc51
« Reply #6 on: 10 Mar 2025, 04:39 pm »
PM sent
