0 Members and 1 Guest are viewing this topic. Read 16901 times.
I am going to put my rack on top of a small rug with rubber backing.
Oh wow, if you can make a 175 pounds speaker move by using one finger to make them rock back and forth, there is not much you can do. Isolating everything individually may help, but I doubt it very much.You need to find a way to make the floor firmer, I can see the uncontrolled movement robbing you of resolution.
Wow! Make sure you decouple the rack from the floor. If you've coupled the rack to the floor with spikes, for instance, take them off. I would start off with something cheap such as rubber pads often placed under pianos. If that helps then go to something better like some of the Herbies offerings or even Townshend.
Those MNPCTech Isolators that I posted a link to, look very promising. There are others that use a similar system with ball bearings that are very effective. I have some friends that use them.
I just pulled the trigger on a used set of Daedalus Audio isolation devices that employ ball bearings. I'm gonna try it under my tube DAC. I also purchased a set of IsoAcoustic pucks for my preamp that should arrive this weekend. My amp already rests on a set of those. I'm aware these are Bandaid approaches, but it may be the best I can do under the circumstances.
Those rubber tiles look like they would work. Aesthetically, a nice rug may look better though.
LarryYou can buy the same design of footers on Ali Express for a whole lot less. I've bought several sets in the past and they work the same.https://www.aliexpress.us/item/3256803146953604.html?spm=oneshop.home.dspopularproducts.2.419d7f6bT6p1bu&skuId=12000025263529676&pdp_ext_f=%7B%22sku_id%22%3A%2212000025263529676%22%7D&aecmd=true&gatewayAdapt=glo2usa4itemAdapthttps://www.aliexpress.us/item/3256803504435527.html?spm=a2g0o.order_list.order_list_main.11.97241802c0Xr8S&gatewayAdapt=glo2usa
You can also give these a try but you can find them cheaper elsewhere-https://www.mnpctech.com/products/cork-pads-stop-vibrations-isolation-turntable-record-player-pads?variant=44688377479392
If the floor moves as much as you say, I think you are wasting your time and money till you’ve fixed the floor issue. If you don’t have a good foundation, everything on top of it is useless. You may as well put good isolation on to of a pile of jelly.
