~Sold~ Electrocompaniet AW 180 mono blocks
0 Members and 1 Guest are viewing this topic. Read 693 times.
Sense63
« on: 2 Nov 2024, 11:56 pm »
~Sold~
Mint condition, original owner pair of Electrocompaniet AW 180 monoblocks. Looking to downsize gear which is the only reason for the sale. I purchased these less than a year ago as new A stock from an authorized US dealer. They will drive any speaker out there. The replacement model AW 300M retails for $29,000, so here's your chance to get a basically brand new pair of the previous model with 95 - 98% of the sonics of the newer model.
Retail: $11,200 Asking: $7390
Includes: Original box, manual and power cords.
Zelle, check, cash (if local), bank wire and PayPal F/F accepted.
I would prefer a local sale within a 120 mile radius of the Chicago metro area. Shipping would be a flat $125 via pallet to the lower 48.
Check my feedback out and buy with confidence on USAudiomart under username Mascott. Make a reasonable offer and let's see what happens, however, lowball offers will be ignored.
https://www.enjoythemusic.com/superioraudio/equipment/1210/electrocompaniet_aw180.htm
Output Impedance
(20 Hz - 20 kHz) < 0,008 ohm
RCA (single) input impedance 220 kohm
XLR (balanced) input impedance 110 kohm
Input sensivity for rated output 1 V
Max. peak current > 100 A
THD (measured at 1 kHz
half power, 8 W) < 0,001 %
-1 dB, 8 W) < 0,001 %
Noise
(measured with both inputs shorted) 400 Hz - 30 kHz : 90 µV
10 Hz - 30 kHz : 100 µV
Rated output power
8 ohms 250 W
4 ohms 380 W
2 ohms 625 W
Power consumption
(no load or signal) 115 W
Dimensions
Width 215 mm / 8.5 inches
Depth 470 mm / 18.5 inches
Height 288 mm / 11.3 inches
Weight 22 kg. / 48.4 lbs.
« Last Edit: 8 Nov 2024, 08:08 pm by Sense63 »
