Here is some generalizations:
Groove Tube are TSO’s (tube shaped objects). They resemble tubes in many ways but are far from it. Groove Tubes are garbage!
I have listened to hundreds of tubes of all different types. I’m not exaggerating is the slightest. I buy and sell tubes all the time just to hear them. A good friend of mine does the same thing. Tunes react differently in different types of gear but a Mullard is a Mullard and a Amperex is an Amperex regardless of the component and its sound character (I have found) is consistent. New tubes are bright, edgy and appear to have loads of detail which is just a masking of its lack of bass and mid bass. Seriously, new tubes are crap with few exception. The Elite EL84 is wonderful for a new tube as well as the EI Elite 12AX7 but an Amperex Bugle Boy is so much better its hard to justify the cost savings. Besides, older NOS’s outlive new tubes by almost 2:1/
Most new tubes suck in my opinion and I have heard many of them. Chinese made tubes are the worst. Some Russian tubes are good and the Yugoslavian are better(best).
European tubes have a wide variety of sound to choose from. Mullard (or British made tubes) have most bass but can be a little loose and usually don’t have the best high end. German (Telefunken) tubes are the most neutral bland sounding. Sometimes this is very good and sometimes its boring and dull. Holland made tubes (Amperex bugleboy) are some of the best sounding. Good bass that’s tight, great midrange and a lively top end.
American tubes can be either VERY good (best) to not so great. Amperex and RCA made tube from New York are some of the best made (Amperex PQ’s for example). Sylvania tube are also good. With Sylvania and RCA’s you are looking for triple mica tubes, that are ultra quiet and generally superior sounding. I like black plates over grays but it’s a matter of taste.
I’d try an Amperex PQ (made in USA) with gold pins (white label/lettering) 12AX7 first. If its too lively, try a Mullard (Blackburn plant) and if its not lively enough then try an Amperex BugleBoy made in Holland.
6NS7’s? Try an American made one. Ken Rad, RCA, Sylvania.
READ THIS!! This guy, Joe is dead accurate 98% of the time.
http://www.audioasylum.com/audio/faq/joes-tubes.htmlAnd remember to be aware of TSO’s, they are tricky little objects that cleverly disguise themselves as tubes and ruin the entire listening experience.
