Jolida JD1000A 100w integarted tube amp / NIB
0 Members and 1 Guest are viewing this topic. Read 2222 times.
Bill Baker
    • Musica Bella Audio
« on: 14 May 2005, 09:45 pm »
I have one NIB Jolida JD1000A integrated tube amplifier producing 100 watts per channel with the help of 4 pieces EL34 output tubes per side.
 Original selling price of $1,699 / Asking $1,450
Technical Specifications:
Maximum Power Output:  150 W per channel at 8 ohms, 1KHz
Rated Output Power:  100 W per channel at 8 ohms, 25Hz to 70KHz
Frequency Response:  (at 1 watt into 8 ohms) 8Hz to 130KHz + 1dB
Bandwidth:  13Hz to 80kHz + 3dB; 0dB 100 W 1KHz
Distortion THD:  Less than 1% at 100 W output, 28Hz to 15KHz
Circuit Type:  Ultra Linear, Class AB
Input Impedance:  100Kohms
Input Sensitivity:  500mV at 1KHz and 8 ohms for 100 watt output
Output Impedance:  4 ohms and 8 ohms
Negative Feedback:  Less than 5 dB
Noise and Hum:  85dB below rated output
Tube Complement:  4 matched pairs (8) of 6CA7/EL34 power output; 2 pcs. 12AX7 pre-amplifier; 2 pcs. 12AT7/ECC81 power drivers.
Power Requirements:  110V-120 VAC 60Hz 180 watts-standby, 450 watts maximum (220 VAC 50Hz option).
Dimensions:  17 inches (43cm) wide by 15 inches (38cm) deep by 7.5 inches (19 cm) high.
Weight:  50 pounds (23 Kg) net, approximately 55 pounds (25 Kg) packaged.
Warranty:  Two year limited parts and labor. One year or 1000 hours whichever comes first on Jolida Tubes.
Bias Settings:  40 millivolts + 4 mV
Fuse:  110 - 120 VAC, 6.3 Amp Fast Blo; 200 - 240 VAC, 3 Amp Fast Blo
Bill Baker
« Reply #1 on: 12 Jun 2005, 02:34 pm »
Reasonable offers accepted! If it does not sell by the time I get caught up around here, I may just have to tear it apart for some extreme modifications!!!
