Subwoofer cable recommendations
0 Members and 1 Guest are viewing this topic. Read 1150 times.
devloui
« on: 28 Sep 2024, 02:04 pm »
Hello,
I am currently using two REL S/812 subwoofers.  I have added a Sublime crossover to my audio system, so I am looking for RCA interconnect recommendations.  Also, I am curious, do both subwoofer interconnects need to be the same length?
Thanks for your thoughts.
rollo
  • Rollo Audio Consulting -
Re: Subwoofer cable recommendations
« Reply #1 on: 28 Sep 2024, 03:28 pm »
Triode wire Labs.
charles
sonicxtc
« Reply #2 on: 28 Sep 2024, 08:20 pm »
IMHO,
It's preferably to use cables of the same length, but if the difference is not extreme, then I don't think you'll ever notice a difference in the sound. I've used Zenwave cables 10 foot and 14 foot and never noticed a difference.
Depending on your budget....Blue Jeans cable makes an excellent affordable subwoofer cable that I use in my system.
devloui
« Reply #3 on: 29 Sep 2024, 02:57 pm »
Thanks sonicxtc, I’ve had others who also recommended the blue jeans cable.  Very inexpensive, with several recommendations from others, and a good return policy.  This is probably the one I will try first.
Also, I didn’t think that the difference (in my case I need one interconnect 8’, and the other 12’) in this length would be noticeable.  However, I’ve always believed that both interconnects should be the same length.  I may just call blue Jean, and ask them as well.
Thanks again.
devloui
« Reply #4 on: 29 Sep 2024, 02:58 pm »
Thanks for your suggestion rollo!
I.Greyhound Fan
« Reply #5 on: 29 Sep 2024, 09:52 pm »
Don't break the bank on a subwoofer cable.  I use belden 1505 RCA cable for my dual subs.  I have not noticed any difference in sub cables.  Others may have a different experience.
devloui
« Reply #6 on: 1 Oct 2024, 01:10 pm »
Thanks Greyhound Fan.  Currently, I am using a pair of Kimber Cadence that a friend loaned me.  Sounds very good, but so many have echoed your thought.  I think I’ll try a pair of bluejean cables to compare.
I.Greyhound Fan
« Reply #7 on: 1 Oct 2024, 05:12 pm »
Give the BJC 1505 RCA cable a try.  Also, I recommend keeping the cables the same length.  It won't make a difference with short distances but I like to keep them the same.
devloui
« Reply #8 on: 3 Oct 2024, 01:58 pm »
Greyhound,
Thanks for your suggestion about the 1505 BJC.  Do you know what the difference between the BJC LC-1 versus the 1505 is?
I.Greyhound Fan
« Reply #9 on: 4 Oct 2024, 03:52 pm »
Greyhound,
The 1505 has better shielding.  The LC2 has a heavier shield.  It is also a slightly smaller gauge and has a higher capacitance.
Either one will work.  I did not need the heavy shielding.  So I went with the 1505.
« Last Edit: 4 Oct 2024, 05:03 pm by I.Greyhound Fan »
I.Greyhound Fan
« Reply #10 on: 4 Oct 2024, 05:00 pm »
Here is another place to buy good cables at great prices.  I have bought various cables from this site. They will make custom lengths.
https://www.ghentaudio.com/products/e08?VariantsId=15652
js1955
« Reply #11 on: 7 Oct 2024, 10:24 am »
I use long runs (20 ft) of BJC LC-1 on my pair of subwoofers.  Works fine.
I wouldn't fret too much about sonic differences between these cables for LF duty.  Just get something decent from a reliable mfr.
https://www.bluejeanscable.com/store/subwoofer/index.htm
rif
  • Not a cowboy
« Reply #12 on: 7 Oct 2024, 06:17 pm »
I also use 1694 coax, some BJC, some home made.  One thing to note: I really don't like the rca connectors that BJC uses.  Nothing wrong sonically, and they are well made.  Just something about them I didn't like, sorry but I can't remember what.
