Re: Using Bryston 2B-LP case for ground of REL Subwoofer
0 Members and 1 Guest are viewing this topic. Read 1176 times.
SHXMD
Hello!
Quick question-I think.
REL has changed recommendation of High level connection of ground wire(black) from speaker terminal negative to Amplifier case screw-usually lid.
Any reason to not do this on the 2B-LP?
Also, was going to use case screw at side.
Thoughts? Worries Concerns?
Don’t have a proper available ground screw and console is wood.
