0 Members and 1 Guest are viewing this topic. Read 3811 times.
I'm trying to keep my HT space efficient by trying to "hopefully" have one DVD/CD unit for the main system (I don't care about DVDA or SACD).Since VMPS are highly resolving, can any of you recommend a great DVD/CD player (under $2k) that justifies[/u] being in the same room with the VMPS?.....or are all existing units so grating that you'd recommend me to go for separates....and if so, which ones?........Could a Pioneer 588 or 59AVI and their similar ilk do the job or am I lo ...
Along the same tac as LKosova, some love to put "tubes" in the front end of their VMPS systems.Tube CDP and PreAmps.To that end, you might also find the Jolida JD-100 to your liking. It is priced well (less than $1000) and has been reviewed favorably. It was on my short list.
Quote from: John CaslerAlong the same tac as LKosova, some love to put "tubes" in the front end of their VMPS systems.Tube CDP and PreAmps.To that end, you might also find the Jolida JD-100 to your liking. It is priced well (less than $1000) and has been reviewed favorably. It was on my short list.How would a tube CDP along the likes of the EE Minimax compare to the Jolida JD-100?........
