0 Members and 1 Guest are viewing this topic. Read 7755 times.
I purchased one in December of 2023 due to all the great reviews, but never used it as I changed my system config and run Roon directly into my speakers Dutch and Dutch 8C's) via Ethernet.You can check with the person who bough it (ebag4). I think he has been very happy with it.George
The Holo Spring 3 is available with a pre-amp module that is identical in design principle to the one in the A8: "Fully discrete and balanced relay controlled volume control."Could Tim at Kitsune add the preamp module into the Spring 3 for you? I would definitely go that route rather than get the A8 just to use it as a pre-amp.
Ahhh, ok.It's an interesting comparison. Your existing setup is excellent with (my guessing) the pre-amp being a weaker element.I think shorter digital and analog signal paths and designing all elements to work together could offer an advantage for the A8, but you have a very good digital transport and DAC.If you go the A8 you could stream Tidal via Ethernet. It will turn off WiFi when connected via Ethernet, so the RF noise from WiFi is gone from the system.In every case that I've compared Ethernet to WiFi, the Ethernet has sounded best. It's definitely worth using Ethernet with the A8.
I'll be curious to hear how it goes if you give the A8 a try.
