MXR Linear Preamplifier with phono $175
0 Members and 1 Guest are viewing this topic. Read 824 times.
apt_one
« on: 22 Sep 2024, 12:08 am »
MXR Linear preamplifier model 139-excellent low profile preamp.
https://www.gammaelectronics.xyz/audio_11-1981_mxr.html
Payment via paypal friends and family option only, buyer pays ground shipping cost.
[email protected]
Manufacturer's Specifications:
Rated Output Voltage: 1 .0 V rms.
Maximum Output Voltage: 7.0 V rms.
Gain: Phono, 40 dB at 1 kHz; high level, 0 or 20 dB, selectable.
Frequency Response: Phono, RIAA ±0.25 dB; high level, 20 Hz to 20 kHz ± 0.25 dB, 10 Hz to 100 kHz-3 dB.
S/N Ratio: Phono, 88 dBV; AUX or line, 90 dBV; minimum volume, 95 dBV.
THD or IM: 0.005 percent, rated to maximum output, line or phono.
Phono Input Impedance: 47 kilohms and 200 pF.
Phono Input Sensitivity: 5 mV rms.
Phono Input Overload: 120 mV, 1 kHz, peak.
High Level Input Sensitivity: 50 mV rms.
Low Filter Response: -3 dB at 19 Hz, -29 dB at 5 Hz; phono only.
Crosstalk: High level to phono, 80 dBV.
Headphone Power: 150 mW.
Slew Rate: 7 V/µS.
Output Impedance: 600 ohms.
Dimensions: 19 in. (48.3 cm) W x 6 1/2 in. (16.5 cm) D x 1 3/4 in. (4.4 cm) H.
