Have to reset Bryston DB after every reboot on BDA-3.14
0 Members and 1 Guest are viewing this topic. Read 2315 times.
Busseysound
Upgraded from a BDP-2 to a BDA-3.14 a couple of weeks ago.  Took the 4TB SSD internal drive from the BDP-2 and put it in an external case to attach with USB to the 3.14.  Everything worked fine for a short time, but now every time I reboot I have to reset the Bryston DB for anything to show up in the Artist View.  I can access the files just fine through SMB or in the default view in Manic Moose, but nothing in the Artist view.  Things I've tried:
Factory reset
Clear MPD cache
Clear Bryston DB cache
Static IP and DHCP reservation
Some other things I'm sure I haven't mentioned.
Anyone have any ideas?
WillyP
Re: Have to reset Bryston DB after every reboot on BDA-3.14
« Reply #1 on: 6 Sep 2024, 08:20 pm »
Are you sure the BDA-3.14 has enough power for a 4 TB SSD? Does the SSD have it's own power adapter or is it powered by the BDA-3.14?
My BDA-3.14 worked without flaws with both an 1 TB HD and an 1 TB SSD, but had serious problems with a 2 TB SSD.
WillyP
Busseysound
« Reply #2 on: 6 Sep 2024, 10:31 pm »
Yep - the drive is an external SATA case that has its own 12V 2A power.
Alfalfa
« Reply #3 on: 7 Sep 2024, 02:58 pm »
I’m currently running a similar configuration andit works but..
I cannot use artist, genre or album search functions and it seems very limited in capacity for ‘favorites’ etc.. I suppose this is the difference between an all-in-one device and a specialized digital player, but I’m only guessing here.
It can deal with the externally powered harddrive thoiugh.
Stefan_DR3
« Reply #4 on: 19 Sep 2024, 02:32 am »
Just a thought but have you tried the upper left "update" button (in the Update  Clear  Consume  /  Eject list)?
