Chokes and Capacitors in Electronic gear
0 Members and 1 Guest are viewing this topic. Read 2430 times.
BrandonB
« on: 22 Aug 2024, 07:24 pm »
I know this forum is focused on speakers but I also know that allot of you are knowledgable in electronics.  I was talking to an owner of a company who is also an EE about his DAC's.  He talked about the quality of the internal parts of his equipment which seemed pretty nice (Lundahl, Furutech, Vishay etc..). He also talked about having chokes in the power supply.  He said nice equipment will have chokes including DAC's Preamps, Amps etc.  In  conversations on this forum people have said they have moved into DAC's with tubes which would usually include chokes. They have said that tube DAC's just sounds more natural and have a better tone and pace.    Also I have heard that more capacitance in the power supply is better.  Danny talks a lot about the quality of capacitors in the crossovers but in the power supplies I read more about the amount of capacitance which makes sense.  Let  me know if you have experienced these as truths.
Early B.
Re: Chokes and Capacitors in Electronic gear
« Reply #1 on: 22 Aug 2024, 10:08 pm »
Great sound quality requires high parts quality. It's no different than any other product.
For audio, the sound is in the power. Take Class D amps, for example -- the best ones are as big as A/B amps and just as expensive due to their massive power supplies, often with chokes. Another way to look at it -- nearly every amp manufacturer's statement amps are much larger than their other offerings for the same reasons. Same with monoblocks vs. stereo amps. A third way to look at it -- audiophiles prefer separates because of better sound due mainly to their power supplies.
Most streamers have low-cost switching power supplies. I built a custom linear power supply for my streamer to get better sound.
HAL
« Reply #2 on: 23 Aug 2024, 02:46 am »
Even switch mode power supplies (SMPS) use inductors (chokes) and capacitors in the outputs for low pass filtering, just like tube amps.  The difference is the frequencies they need to filter out.
For AC power supplies they are in the 60Hz, 120Hz and harmonics frequency range in the US and 50Hz, 100Hz and harmonics in the UK.  These require large values for the inductors and capacitors, typically meaning large iron core inductors and electrolytic capacitors.
In SMPS, the switching frequencies are in the 100KHz and higher frequencies for modern units.  The values of the required inductors and capacitors are small and typically can be better quality like low ESR capacitors and ferrite core inductors.
If you know Gary Dodd's battery powered tube amps, he used SMPS for the tube high voltage.  That is the way to get the 12VDC battery power to 300VDC for the power tubes.   They are great sounding amps.  No one complained of noise problems.
A lot of digital electronics also have voltage regulators after the SMPS to provide different voltages for the DAC's and control electronics, most importantly the main clock oscillator.  That prevents noise jitter in low phase noise oscillators.
Good luck with your search.
jmimac351
« Reply #3 on: 24 Aug 2024, 01:10 am »
I've used and still have top shelf tube equipment.  Chokes / caps, it's never been a consideration for me when trying something.
Zero Negative Feedback?  Oh yes...
BrandonB
« Reply #4 on: 24 Aug 2024, 02:08 am »
I do see much of the nicer gear with zero negative feedback.  The new Spatial Audio revelation raven preamp has no Caps in the signal path and is zero feedback.  I know Ayre equipment has zero feedback also.
stylerb
« Reply #5 on: 24 Aug 2024, 03:03 am »
pretty sure all gear employs some degree of feedback. it might have "zero overall" but that doesnt mean zero anywhere.
mkrawcz
« Reply #6 on: 24 Aug 2024, 12:01 pm »
The First watt M2(and Diyaudiostore M2X) has NO feedback as stated by Nelson Pass and it sounds amazing.
Jaytor
« Reply #7 on: 24 Aug 2024, 02:48 pm »
Actually, the source resistors on the output Mosfets do provide some local negative feedback. There is, however, no global negative feedback.
stylerb
« Reply #8 on: 24 Aug 2024, 08:57 pm »
every device has some type of feedback. its impossible not to. it is possible to use semantics to get around the issue but really saying there is no feedback is a marketing statement. not going to argue with Nelson, i greatly respect him, but everything has feedback whether its called feedback is another story.
jmimac351
« Reply #9 on: 24 Aug 2024, 10:05 pm »
Semantics. Context.
stylerb
« Reply #10 on: 24 Aug 2024, 11:00 pm »
feedback per se is not a bad thing. designing a product is a series of goals and compromises and theres no one best way to do things. theres a good thread on diyaudio that bob cordell, nelson pass and john curl have contributed heavily to, interesting read but also a lot of math.
jmimac351
« Reply #11 on: 25 Aug 2024, 12:19 am »
« Last Edit: 5 Dec 2025, 07:41 pm by jmimac351 »
stylerb
« Reply #12 on: 25 Aug 2024, 08:14 pm »
i have the Ayre AX5 Twenty as my amp. nice gear.
im just saying that everything has some type of feedback.
this is a fun read: https://www.head-fi.org/threads/schiit-happened-the-story-of-the-worlds-most-improbable-start-up.701900/page-9040#post-17911208
Glady86
« Reply #13 on: 26 Aug 2024, 09:51 am »
I guess this is related to the topic. I used Miflex capacitors in my high pass filter. I didn’t think much of break in, but something’s definitely going on. A couple recordings that Ive played and know well sounded a little off, edgy and cold. Yesterday I played again and it was the best I ever heard them. Do these capacitors change in character that quickly? Probably about 60 hours on them.
And no I wasn’t drinking, to those who might not believe.
« Last Edit: 26 Aug 2024, 11:41 am by Glady86 »
bardamu
« Reply #14 on: 26 Aug 2024, 10:13 am »
Hello, I think it is important to look for the right capacitor in the right place. I my high pass filter ( 600 hertz and up) . I tried a few including some '' audiophile brands '' but the best one for me where some Philips paper( in oil?) caps from the sixties bought in a surplus sture for a $ a piece. Greetings, Eduard
P.s yes the bigger CSI caps ( 5 or 6 KV) took several days before giving a decent sound. The Philips took a few hours and kept improving the first days. If i remember right i got more detail.
Glady86
« Reply #15 on: 26 Aug 2024, 11:44 am »
I always thought all those big cans were electrolytic types. It’s cool you found a cheap alternative to the expensive fancy ones.
bardamu
« Reply #16 on: 26 Aug 2024, 12:56 pm »
Hello,
I know the biggest ( CSI) cap is a brand that also made lots of special foil caps.  BUT they also made caps that are not made to be used with DC voltage applied for a long time. They are made for special equipment and can only be used in a special way. SO you have to know what you are buying. Right now there is a set of transformers for sale online and advertised as being perfect for a tube amp. But on the transformer it is clearly indicated '' duty cycle 5 minutes on 10 minutes off or transformers made to be used between 400 and 1100 CPS/Hertz.
The dark grey GE( dielektrol) caps contain some kind of oil and they works really well.Usually if it says no pcb there will be a less dangerous oil inside.
As you can see in the photo i had my share of audiophile caps  But many times i have had older caps that sounded a lot better.
Of course you could say progres will allow manufacturers to make better products. But most of them are not interested to make a product that would make them feel proud. Kind greetings, eduard
