OFF : Liberty audio B2B-100 power amplifier w/upgraded WBT and cardas connectors
0 Members and 1 Guest are viewing this topic. Read 1659 times.
Cacophonix
Sold to a local audiophile.
Looking to change out my setup a bit. I’ve had this paired with a topping pre90 and the combination has been absolutely amazing.
Made in USA and designed by the venerable Peter Bichel Noerbaek of PBN Audio, this is a balanced dual mono amp that nearly doubles to 4 ohms. Extremely well built, no noise, warm sounding and doesn’t run too hot. Perfect for Texas weather 😃
These have the upgraded WBT speaker terminals and cardas XLR connectors.
B2B-100 Technical Specifications
Class A/AB Power amplifier
Power output into 8 Ohm = 110WPC @< 0.1% THD Power output into 4 Ohm = 200WPC @ <0.1 %THD
Mono Block Operation Power into 8 Ohm = 350W @0.1% THD*
Mono Block Operation Power into 4 Ohm = 600W @0.1% THD*
Power Consumption 200W in High Bias, 100W in Low Bias @ Idle 700W max
Input Impedance 75K Ohm RCA, 3K6 Ohm Balanced (1K8 Ohm per leg)
Dimensions 19″ W x 5.75″H by 16″D
Weight 50 lbs.
$800 for local pickup in Dallas area. Shipping can be arranged and will be extra.
« Last Edit: 3 Jan 2025, 09:03 pm by Cacophonix »
