Magneplanar .7
0 Members and 1 Guest are viewing this topic. Read 3101 times.
kelecoleman
Magneplanar .7
« on: 15 Aug 2024, 02:43 am »
Hello, new member here.  Just got the Magnepan .7 upgrade kit. Can’t wait to get into it.
I’ll post something about it, eventually.
AK-Grwn_v2
Re: Magneplanar .7
« Reply #1 on: 18 Aug 2024, 05:08 am »
Good luck!
Danny Richie
Re: Magneplanar .7
« Reply #2 on: 20 Aug 2024, 03:49 am »
That's great. Let me know if you need anything during the build.
David A
Re: Magneplanar .7
« Reply #3 on: 8 Sep 2024, 06:21 pm »
Thank you for sharing the details of your Maggie .7 crossover upgrade with the GR Research kit!  I am thinking about the LRS Plus upgrade.  I will be very interested to learn your impressions of the .7's sonic characteristics before and after the GR Research upgrade.
Hobbsmeerkat
Re: Magneplanar .7
« Reply #4 on: 16 Sep 2024, 03:48 pm »
Danny, can I solder the mid-panel negative lead to the bottom of the tweeter inductor?  The bottom of the tweeter inductor is getting signal from the negative input.
To me, the novice, it looks like this would feed the tweeter circuit to the mid-panel.
Thank you
The negative return of the mid panel can either go direct to the white tube connector, or connect to the inductor on the circuit tweeter, namely to the side of the coil with Tweeter+ and input -
(not the same side as the capacitor & tweeter-)
The cap in the tweeter circuit prevents any mid/bass signal from passing through the tweeter panel.
Danny Richie
Re: Magneplanar .7
« Reply #5 on: 25 Sep 2024, 01:56 pm »
Thanks for the great feedback.
