What is the bettery method of transfer?
0 Members and 1 Guest are viewing this topic. Read 2608 times.
« on: 6 Aug 2024, 03:21 am »
If using the same computer/server and the same DAC, what is the better method of transferring music?
USB?
Optical?
Coaxial?
nlitworld
Re: What is the bettery method of transfer?
« Reply #1 on: 6 Aug 2024, 04:08 am »
I've found optical is usually a solid step down in quality. I've heard many people say coaxial is better than usb but I've yet to hear otherwise when all things were equal with quality cables. I'm sure most of it comes to how each design is implemented into the piece of gear. Currently usb in my setup for actual music playback, and optical for integrating my tv/video games only. Curious to see what other people are running and why.  :popcorn:
WGH
« Reply #2 on: 6 Aug 2024, 06:08 am »
I have used all three transfer methods. I now use USB because all music is upsampled to DSD256 using a dedicated high power music server into the HoloAudio May KTE DAC.
Optical has to be converted to an electrical signal so quality depends on what 15¢ part is used. Optical is a fiber glass version of SPDIF so it adds even more jitter than Coax.
Coaxial is always a solid choice for 44.1 and 96 kHz recordings.
High-res almost always requires USB and a lot of times a driver needs to be installed too.
A lot more technical stuff that can be done to a digital signal. The HoloAudio May KTE has a lot of USB enhancements and other technical stuff, click on the link for a deeper description
https://www.kitsunehifi.com/product/holo-audio-may-dac/
"The May DAC has the new and exclusive USB Enhanced module (L2 and KTE ONLY) which has our FPGA with the new Titanis 2.0  and custom firmware to improve USB Eye Pattern and reduce latency to near zero as well as reduce jitter to very very low levels. The USB module has completely new code written to optimize performance and reduce latency significantly. Low frequency performance (-40db) is also improved. The “enhanced” USB xmos module is twice as powerful/capable as the one that is used in the Spring2."
newzooreview
« Reply #3 on: 6 Aug 2024, 04:30 pm »
What DAC are you using? There's not a generic answer. There's also I2S via HDMI in many DACs. Does your DAC allow that option?
