Best new or used cd player for under 1k??
0 Members and 1 Guest are viewing this topic. Read 1866 times.
sts9fan
« on: 12 May 2005, 06:15 pm »
I am looking to upgrade(shocking) my player and suggestions?
ss397
« Reply #1 on: 12 May 2005, 06:42 pm »
RAM fully modded Toshiba 3960. the performance is startling.
ken_diyzone.net
    • http://www.DigitalAnalogueDIY.com
« Reply #2 on: 12 May 2005, 07:19 pm »
Hi,
If you are into DIY, may I suggest our player.
http://www.digitalanaloguediy.com/cd-pro2.html
Ken
TIC
« Reply #3 on: 13 May 2005, 12:19 pm »
The Quad 99CDP CD player sells for about $850-950 used. It is very, very good! Not only is it a good CD player, but it has an excellent variable volume control so you can run it direct to a power amp if you want. It also has 6 digital inputs so you can connect other digital sources to it and use its built-in 24bit/192khz DAC to improve the sound of a component like a DVD player.
I've owned several CD players that listed for $2500-3500 and now that I own the Quad ($1500 msrp), I don't miss them at all!
Enjoy,
TIC
Feisal K
    • DVD-A registry
« Reply #4 on: 13 May 2005, 01:15 pm »
if you CD Player has a digital out, why not add a DAC? The Benchmark DAC-1 seems to be generating some waves
warnerwh
« Reply #5 on: 13 May 2005, 04:45 pm »
A Marantz SA8260 is excellent on both redbook and SACD.  The improvement over my Sony 555es cd player amazed me as I figured only subtle differences.  Midrange is rich and lush and the treble so smooth and articulate while the Sony was bright and hard and vocals just didn't have the body I thought they should have.  At bare minimum worth trying. I've noticed hardly any for sale on Audiogon.
Jonathan
« Reply #6 on: 20 May 2005, 03:36 am »
Quote from: warnerwh
Agreed.  I just bought one used a few weeks ago, and I like it very much. I prefer it over the Benchmark DAC1 I owned before the 8260.
Note: be careful if you're going to buy an 8260 on the used market because there was a firmware bug on some of the older models that resulted in the machine failing to play some SACDs.
