Bryston BDA-2 Dac
0 Members and 1 Guest are viewing this topic. Read 1738 times.
[email protected]
Bryston BDA-2 Dac
« on: 24 Jul 2024, 04:50 pm »
Hi, What does everyone consider the best sounding connection to preamp? Thanks in advance.
gbaby
Re: Bryston BDA-2 Dac
« Reply #1 on: 24 Jul 2024, 08:41 pm »
While I admit to being a little slow, I can say that your question is a little too vague for me to respond. :icon_surprised:
shawngt2
« Reply #2 on: 24 Jul 2024, 09:34 pm »
Balanced XLRs for shielding, but probably doesn't matter vs single ended unless you are running a long distance. Sure someone else with more knowledge will chime in.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #3 on: 24 Jul 2024, 10:15 pm »
One of the advantages of using USB is the DAC controls the quality level of the digital playback rather than the source.
james
shawngt2
« Reply #4 on: 25 Jul 2024, 10:32 pm »
Hi James, OP was asking for best connection from BDA-2 to pre-amp. USB? Am I missing something? I have XLRs connected, so would definitely want to take most advantage to my BP-17^3.
« Reply #5 on: 26 Jul 2024, 10:55 am »
 :duh: :duh: :duh:
Sorry - then the answer is Balanced.
james
