Northwest Audio Review June 4,05 at RAW Acoustics
0 Members and 1 Guest are viewing this topic. Read 2052 times.
RAW
« on: 12 May 2005, 02:14 pm »
Well after a few months since the DIY event ,RAW Acoustics will be holding a day for those wanting to come and listen to all the kits design from RAW Acoustics, Exodus.
For the day we will have the following ready for you to have listen to.
RAW 1
RAW 1F
RAW HT1  CSS125S AC ribbon
RAW HT2  CSS125ST AC ribbon MTM
RAW HT3  AC,CSS125S,sidefiring Extremis
RAW HT6 Extremis and AC ribbon
Exodus kits
41
241
16
261
LCR
See you then.Maybe  Kevin and Dan may hook up for the trip.
Al
RAW Acoustics
16756 -85 Ave
Surrey BC
Canada
604-576-8951 [/u]
kfr01
« Reply #1 on: 12 May 2005, 04:17 pm »
Well.. for those of us that can't make it I hope that someone does some nice reviews.
Merits / Impressions of LCR v.s. 61 v.s. HT3 for 2-channel audio, etc.
Anyway,  the one source of hesitance in buying the more expensive kits is not being able to hear them before buying.
On that note, Kevin, Raw, Bob, anyone else ... have you heard or seen any unsolicited reviews of the LCR kit?  Has anyone been able to A/B the LCR v.s. kit61 for stereo listening?
Kevin P
    • http://www.diycable.com
« Reply #2 on: 12 May 2005, 04:24 pm »
Quote from: kfr01
Ask Al Garay.... he has had the chance to listen to both the KIT61s & LCRs.   We don't have any affiliation with him so you should get an unbiased opinion (I know it's a good one).  ;-)
The kits havn't been out long so it will take awhile for most people to get them built and develop an opinion.
From my personal experience the reviews from people who own & live with a product are much more valuable than those done at shows and events.   It's hard to give something an honest evaluation until you own it.
mb
« Reply #3 on: 13 Jun 2005, 01:01 am »
Any comments / writeups from attendees? Very interested in hearing views about the HT6, HT3 and comparable Exodus kits.
RAW
« Reply #4 on: 14 Jun 2005, 04:06 am »
http://www.diyaudio.com/index.php?s=56747e84ab8e67e6d54292e172750fde
There was a 7 page thread on the event and some how it got removed.
So all those who commented on the event over at the DIY posts have been removed.
Try posted over there and see if you get a responce as I know a lot of those who attended post over at DIY.
Al
