A370 Amp Question
0 Members and 1 Guest are viewing this topic. Read 838 times.
jimbones
A370 Amp Question
« on: 30 Jun 2024, 10:34 pm »
Is this amp Inverting or non inverting amp? TY
walkern
Re: A370 Amp Question
« Reply #1 on: 1 Jul 2024, 01:26 pm »
I have one of these, and I believe it is non-inverting... however it does have a phase control so you can adjust it up to 180 degrees, so it shouldn't really matter what the default phase is.
jimbones
« Reply #2 on: 1 Jul 2024, 01:54 pm »
True TY. I just wanted to know where my "starting" point was. I have some amps that invert, some that dont so i want to ensure they are all synched in phase
mlundy57
« Reply #3 on: 1 Jul 2024, 04:29 pm »
Even if they are in absolute phase, depending on where the subs are located compared to the main speakers they may not be in phase at the crossover point. I’ve found REW to be invaluable in determining the phase relationship at the crossover point and adjusting the subs accordingly so they sings and mains sum properly.
