BR-20
0 Members and 1 Guest are viewing this topic. Read 2903 times.
shaun666
BR-20
« on: 30 Jun 2024, 10:20 am »
Hi all,
I’m currently using BDA-3.14 / 4B3.
Would there be a significant improvement in sound quality if I replaced the BDA-3.14 with a new BR-20?
Many thanks
Shaun
  • The Demo is Everything!
    • http://www.bryston.com
Re: BR-20
« Reply #1 on: 30 Jun 2024, 12:50 pm »
Hi Shaun
From a Streaming and DAC perspective no difference.  From a Preamp perspective a totally new fully balanced circuit design.
james
shaun666
Re: BR-20
« Reply #2 on: 30 Jun 2024, 03:20 pm »
Hi James,
At the moment I’m using the 3.14 digital volume control, whereas the BR-20 offers an analogue volume
Does this mean the BR-20 clearer, more detailed sound at lower volume levels than the 3.14?
Many thanks
Shaun
Re: BR-20
« Reply #3 on: 30 Jun 2024, 08:29 pm »
Its a hard question to answer because at this level of performance things are incremental in their differences but I prefer analog volume controls over digital ones because digital volume controls loose bits as you turn  the volume down.
james
Nitsuave
Re: BR-20
« Reply #4 on: 20 Aug 2024, 02:04 am »
Hi all,
Many thanks
Shaun
I replaced a 3.14 with a BR20 earlier this year to connect to my 4B3.
With the BR20, there was an improvement in focus and overall soundstage.
Other benefits were a volume readout, a max volume setting, and it’s HT bypass feature.
Blueshound
  • Matrix Audio Featuring the T10 Active System
Re: BR-20
« Reply #5 on: 20 Aug 2024, 12:08 pm »
How does the HT Bypass feature work?
Brian
alanford69
Re: BR-20
« Reply #6 on: 20 Aug 2024, 02:34 pm »
Hi Shaun, in my opinion the 4B3 driven by the BR-20 analog preamp section plays in another league and cannot be compared with a digital volume control which is more a workaround not designed for the best audio quality. I own a 4B3 + BR-20 combo and I can tell you they sound in an incredible way.
Additionally, the BR-20 embedded streaming computer is slightly more powerful than the one embedded into the BDA-3.14 but this will not affect the audio quality.
As a cost-effective alternative, why don't you try adding a second-hand BP-17 or BP-26 preamplifier to your system?
shaun666
Re: BR-20
« Reply #7 on: 20 Aug 2024, 03:12 pm »
I was thinking about that very same idea, many thanks!
Shaun
alanford69
Re: BR-20
« Reply #8 on: 20 Aug 2024, 04:05 pm »
shaun666
Re: BR-20
« Reply #9 on: 4 Sep 2024, 02:38 pm »
I had a demo of a BR-20/4B3 combination with Sonus Faber loudspeakers with a pal today.
We were both absolutely amazed to hear CD quality recordings that actually sounded better than vinyl in an A/B comparison.
The salesman quickly noticed on to how impressed we were so I got the full Glen Garry/ Glenn Ross SMS sales bombardment after the demo.
The Dutchies know how to close a deal!
I think I probably will buy one and the leave the old record collection as a room decoration
alanford69
Re: BR-20
« Reply #10 on: 4 Sep 2024, 04:51 pm »
Happy to hear that! I am not a vinyl fan but it’s true that some albums have a decent dynamic range only in the LP release while on CD they are terribly compressed due to a crazy “loudness war” logic.
But with good recordings… cd quality and hi-res file sound way better!
shaun666
Re: BR-20
« Reply #11 on: 5 Sep 2024, 05:05 am »
After listening to the BR-20 I couldn’t agree more!
