Other Stuff
Archived Manufacturer Circles
DIY Cable
Apex 4-Way at Adire
Apex 4-Way at Adire
0 Members and 1 Guest are viewing this topic. Read 2196 times.
klh
Apex 4-Way at Adire
11 May 2005, 08:42 pm »
Kevin... will you sell this when it's finished? If so, can you estimate a time frame? Do you know how the drivers will be arrranged in the enclosure? I imagine these will be around $800-1000 each... please correct me if I'm wrong.
Bob Reimer
Apex 4-Way at Adire
11 May 2005, 10:01 pm »
Given that the crossover parts retail at around $280 the kit price would be around $1560 per pair. It's not clear when we will have crossover parts and do some testing. There is a 3rd WR125S on the back with an L-PAD to act as a "presence" control.
Bob
Kevin P
Apex 4-Way at Adire
Reply #2 on:
11 May 2005, 10:45 pm »
As Bob says... we will probably release the design but not make it an official kit. The kits have documentation and we carry all the crossover parts, bits and pieces. The Apex probably isn't going to sell in enough volume to justify our investment in time/money/resources to carry all the parts and work up more documentation than we already have.
I'd be happy to square you away with all the parts though.
klh
Apex 4-Way at Adire
Reply #3 on:
11 May 2005, 11:48 pm »
It'll be interesting to see how it pans out. Do you know if it'll be a WWMTMWW alignment with the 3rd WR125S on the back (as the last part was previously mentioned)? That was just a guess.
Kevin P
Apex 4-Way at Adire
Reply #4 on:
11 May 2005, 11:51 pm »
Yea.... the design is done. It has four Extremis's per side. If that isn't enough bass & headroom for you then you need your head examined.
There are two WR-125s on the front and one in the rear for ambience as Bob explained.
klh
Apex 4-Way at Adire
Reply #5 on:
12 May 2005, 12:03 am »
Sounds crazy
. That sucker will need a huge room
Other Stuff
DIY Cable
Apex 4-Way at Adire
