Confused. How to hook up equalizer to preamplifier and amplifier.
0 Members and 1 Guest are viewing this topic. Read 2683 times.
rockthecatbox
I have a Yamaha mx-80 amplifier, adcom gfp-750 preamplifier, and akai ea-a7 equilizer I would like to use together but I am confused how connect them correctly.  The preamp has tape in/outs, external processor in/outs and unbalanced outputs in/outs.
Usually they use RCA cables, you will nees 2 rca cables.
Do you want the EQ before or after the Pre-amp?
Speedskater
  • Kevin
I think that the EQ would use the external processor in/outs.
AllanS
If interested I’d suggest Googling tape in/out (loop) and processor in/out (loop) to understand the functional differences.  I’m not clear on all the differences of how the signals are routed internally and how they are manipulated but would suggest starting by using the processor in/out.  Functionally, as you would use it, this is preferred.
If the images I found are correct, your preamp has a processor toggle switch on the front panel.  In one direction the internal preamp section output (before volume control) is routed to the processor output.  That output is routed to the input of your EQ and the EQ output routed back to the processor.
With the toggle switch in the other direction the processor loop is bypassed and the internal preamp section output goes where it would otherwise go.
Functionally I think the difference between tape and any other component input on a preamp is the addition of tape out, which simply allows you to record the selected input.  For the EQ to be in the signal path of whatever you are listening to, you’d have to select Tape as your input.  Without a Tape monitor button on your preamp (which, if present and with a compatibly equipped tape deck, would allow you to listen to what you’ve recorded) I’m guessing you’d still be listening to the desired device (eg Tuner, CD, Aux 1, Aux 2) but the signal path would be unnecessarily complicated and confusing.
So using the processor loop will allow you to use the input selector as you would normally use it, but provide the flexibility to switch the EQ in and out without degrading or affecting the signal path.  Your EQ will have a button or switch that will bypass the EQ but it won’t be the same thing as the processor toggle switch.
Lastly the unbalanced outputs you mentioned are meant to be plugged directly into your power amp inputs.  Routing these to your EQ might make noise but the input to the EQ would vary with the volume, which you don’t want.  Whatever processor is used and for reasons I cannot explain, the input signal should be constant.
Good luck! While I really appreciate what modern signal processors can do, I’ve always been partial to EQs even if I had no idea what I was doing when turning knobs or pushing sliders.
rockthecatbox
I did a bit of reading on the "tape loop" option for using the EQ.  Since I do not have a "tape monitor" option on the pre-amp, I think this isn't the best option for me.
By the end of my reading I thought I was supposed to go:
preamp processor out >> equalizer in >> equalizer out >> power amplifier in.
However you suggested I use the "unbalanced outputs" from my preamp to connect to my power amp.  I like the sound of that if it means I can choose to bypass the EQ.  I just don't want to blow anything up.  Thanks
AllanS
Yep.  You got it.
Processor Out => EQ Line In => EQ Line Out => Processor In
Pre amp unbalanced out [AKA single ended (SE)] => power amp SE In
rockthecatbox
Thanks very much! I will post a pic of the stack when it's up and running.
