Physical fuse size for IDA-16?
0 Members and 1 Guest are viewing this topic. Read 2733 times.
jonbee
« on: 21 Jun 2024, 12:03 am »
I see that is is 7A slow blow, but what physical size is it?
oskar
Re: Physical fuse size for IDA-16?
« Reply #1 on: 21 Jun 2024, 02:42 pm »
My IDA-16 is at the repair shop. It wouldn't turn on after 3 weeks being powered down.
I pulled the fuse and inserted the spare that's in the same fuse holder. It blew immediately.
So I had the fuses in my hand but not anymore.
You should be able to get that info with a little searching.
Good luck.
« Reply #2 on: 21 Jun 2024, 06:47 pm »
I found this on the Nuprime website:
The following fuses are used in our products:
MCH-K38    T10A
IDA-16       T7A (Slow-blow)
IDA-8        T3A
STA-9        T3A
DAC-9       T1A
HPA-9       T1A
ST-10        T5A
DAC-10     T2.5A
REF-20     T5A
All the fuses have the same size: 5x20mm
