RCA input shorting plugs... for FET valve pre-amp
0 Members and 1 Guest are viewing this topic. Read 2204 times.
Bambudist
« on: 11 Jun 2024, 10:14 pm »
Does anyone use RCA shorting plugs on their pre-amp inputs or anywhere else?  Is this a bad idea for these components or do they help with EMI?
I've seen them used mostly on vintage equipment on the phono inputs but notice I dont see these so much any more.
Are they still used these days?  I have the AVA FET Valve Pre-amp
Thanks for any input!   :wink:
sean619
Re: RCA input shorting plugs... for FET valve pre-amp
« Reply #1 on: 11 Jun 2024, 10:40 pm »
Are you having EMI issues or just general audiophile nervosa?
Bambudist
« Reply #2 on: 11 Jun 2024, 10:46 pm »
Neither just curious.  Anything else to contribute?
avahifi
    • http://www.avahifi.com
« Reply #3 on: 11 Jun 2024, 11:24 pm »
It is ok to use shorting rca plugs on unused inputs, but not on the tape or line level outputs.
I doubt if they will make much difference.
Frank
Bambudist
« Reply #4 on: 11 Jun 2024, 11:29 pm »
Thanks Frank. I'm not having any issues, just curious as some folks were talking about this recently.
