Can a MPS2 power a BP2 phono unit?
0 Members and 1 Guest are viewing this topic. Read 1823 times.
Alfalfa
« on: 10 Jun 2024, 08:09 pm »
I am wondering if a MPS2 power supply can power a BP2 phono unit?
Because of a change from a mm to a mc cartridge I am planning to change the Bryston BP2 mm unit to a BP2 mm/mc variety.
As the BP2 mm will become redundant to me but I will keep the accompanying PS3 power supply I wonder if the redundant BP2 unit can be used by a BP26/MPs2  user who has no onboard phono options?
After all the MPS2 has 4 outputs.
Phil A
Re: Can a MPS2 power a BP2 phono unit?
« Reply #1 on: 10 Jun 2024, 08:40 pm »
https://bryston.com/analog-audio/mps2/
Alfalfa
« Reply #2 on: 11 Jun 2024, 10:50 am »
Thank you Phil, hadn’t thought of that.
HIFI Obsessed
« Reply #3 on: 18 Jun 2024, 12:15 am »
The answer is yes
Just currently purchased a Bp-2 MM/MC 30 phono stage for my Bp-26/ MPS2 power supply and works perfectly.
However with this configuration a special cable is required.
