New to the forum
0 Members and 1 Guest are viewing this topic. Read 1133 times.
mdubyas75
New to the forum
« on: 9 Jun 2024, 07:33 pm »
Hi all. Found this forum as I was researching speakers. In the future I plan to build a 2 channel setup...well 2.1 as I enjoy subs. Hope to gain some newfound knowledge here.
Phil A
Re: New to the forum
« Reply #1 on: 9 Jun 2024, 09:26 pm »
Welcome to AC!
« Reply #2 on: 9 Jun 2024, 11:33 pm »
As you like subs you would try a easy to made OB full-range project as LiiAudio F15 or F18.
Lii Audio F15 FR driver $399/pair, not each.
Here Decware OB with the Lii Audio F15 driver:
If one have a woodworker is possible try the Lii Audio F15($399/Pair, pair not each) 97dB/8Ω and benign impedance curve suited to OB or Bass Reflex box or the F18($540/pair), no Crossover, no Tweeter beaming, no Phase rotation, no driver sensitivity loss, no Harmonics loss, no Retail price.
http://www.glowinthedarkaudio.com/lii-audio-f18.html
My personal choice is the Lii F18 in Single Driver configuration, but if you make question of wanting a 2-Way speaker you may want a bigger woofer than the Alpha15A, so there are W18 inches and W21 inches from Lii Audio, personally I dont like these two VCs woofers, they are hard to drive with a small tube amp.
https://www.lii-audio.com/product/w-18/
https://www.lii-audio.com/product/w21/
Please note some Circles of interest you may like>
The Fullrange Driver Circle:
https://www.audiocircle.com/index.php?board=128.0
The Open Baffle Circle:
https://www.audiocircle.com/index.php?board=90.0
The Tube Amps Circle>
https://www.audiocircle.com/index.php?board=144.0
The Vinyl Circle::
https://www.audiocircle.com/index.php?board=32.0
« Reply #3 on: 10 Jun 2024, 06:01 am »
Greetings & Welcome to AC   :thumb:
kd4ylq
  • Esse Quam Videri
« Reply #4 on: 10 Jun 2024, 08:29 am »
Welcome to the Circle! Lots of good ideas here to sort through and consider. Best wishes assembling an outstanding system.
mdubyas75
« Reply #5 on: 10 Jun 2024, 05:14 pm »
Thank you all for the warm welcome.
mdubyas75
« Reply #6 on: 10 Jun 2024, 05:20 pm »
The Vinyl Circle::
I do have a strong interest in single driver setups so I will definitely check out the fullrange driver circle. I started my research looking at Omega speakers which led me here. Thanks!
