PENDING: Goldmund Studio Turntable Plinth, Metacrylic platter, 24V DC
0 Members and 1 Guest are viewing this topic. Read 1383 times.
crad
PENDING TO WOJ; Goldmund Studio Turntable For Sale, Plinth in nice shape with factory balanced Metacrylic & lead balanced platter, direct drive motor with speed lock, clear Acrylic Cover, custom made Outboard 24V DC Power Supply, Record Clamp and comes with factory well padded double shipping box.
Made in Switzerland. Just needs a tonearm of your choice (linear arm, low compliance ...or ?). Please see all pics. I also have lots of more for you to show, just ask.
All three Springs and all adjustment mechanism parts are there, complete. I've checked and cleaned them. Both 33.3 & 45.0 speeds are good, both lock and measure well. Plinth top is easy to adjust level from top side to balance it flat with the tonearm of your choice, this table gives you lots of tuning options.
The clear acrylic cover is currently detached, the hinges are there and attached to the plinth. The plinth top has a detachable tonearm board (bolted in), currently has an approx. 1" hole and an approx effective distance of 212mm.Sub platter has adjustment to dial in/level platter, plinth top has a built in bubble level.
The plinth itself is clean and free of any damage or cracks, just some signs of use. Motor and bearings are smooth, DC direct motor motor uses a 24V outboard linear power supply made by T.G. (Throbbing Gristle Audio Labs). All three spring locations use a metric hex key to adjust spring tension and raise or lower the plinth top to make level that are very easy to adjust from above.
Local pickup is welcomed, but can ship safely using the large orig. factory double box Goldmund shipping box and packing. This will be well & safely packed.
Price: $1200 or OBO.....plus shipping within the US
Feel free to ask any question, need info or more pics. Thanks
 :beer:
« Last Edit: 4 Nov 2024, 05:45 pm by crad »
