How loud is your CD player?
0 Members and 1 Guest are viewing this topic. Read 2134 times.
rockadanny
« on: 30 May 2024, 04:55 pm »
Curious if you are able to measure db difference between POWER OFF and ON at the device (not at your seat).
S Clark
Re: How loud is your CD player?
« Reply #1 on: 30 May 2024, 06:09 pm »
No difference.  My cd players are Oppos,
psycho1122
« Reply #2 on: 19 Jun 2024, 12:45 pm »
+1 on the OPPO's   :thumb:
Digi-G
« Reply #3 on: 19 Jun 2024, 01:16 pm »
Oppo here too (BDP-95).  I've never measured it but I assume you're asking about operational / fan noise.  Once in a while, usually between songs, I can hear some fan noise.  The music masks any other noise I might hear.  I only hear slight spinning noise on startup and stop, not while the disk is spinning.  Honestly, in my listening position there is enough other ambient noise (a/c, 4 dogs, wife tapping on her phone or computer, birds outside, etc. that any operational noise is almost mute.  I turn the volume up.  :D
These observations are in my seated position.  If you're right on top of the unit, especially without music playing, the fan noise is more noticeable (when running).
I do play a lot of digital files through the Oppo as well from a solid state drive.  The same comments apply except there is an addition click, like the sound of a relay, between every song, during the silence.  I don't know what this is or why it does it.  This sound is from the player, not through the speakers. I've been curious if anyone else experiences this.
Speedskater
  • Kevin
« Reply #4 on: 20 Jun 2024, 04:16 pm »
I put Sorbothane Hemispheres under CD/DVD players to reduce the shelf acting as a sounding board.
