Audio/Video Gear and Systems
The Lab
sts9fan
How to isolate transformer vibrations from case?
0 Members and 1 Guest are viewing this topic. Read 2536 times.
rockadanny
It's all about the music.
28 May 2024, 04:39 pm »
This is inside a CD player so transformer is small.
Volunteer
Audio Transformers Consulting
Re: How to isolate transformer vibrations from case?
28 May 2024, 04:53 pm »
Rubber soft or mid density foots IMO.
As an audiophile alternative there is sorbothane.
Speedskater
Kevin
Reply #2 on:
28 May 2024, 05:47 pm »
You might be able to find some shoe inserts that are made of Sorbothane®.
newzooreview
**Not a reviewer**
Reply #3 on:
28 May 2024, 08:03 pm »
Herbies makes a variety of vibration control feet, including some small ones:
https://herbiesaudiolab.com/collections/component-isolation
Speedskater
Kevin
Reply #4 on:
29 May 2024, 11:42 am »
From Edmund Optics
https://www.edmundoptics.com/search/?criteria=Sorbothane&Tab=Products#
rockadanny
Reply #5 on:
29 May 2024, 12:43 pm »
Thank you all and thank you for the links
rollo
Restricted
Rollo Audio Consulting -
Reply #6 on:
29 May 2024, 03:16 pm »
If you are handy try making a silicone ring. Remove transformer and put under it. Learned that from Angela/Gilbert Yeung formerly Blue Circle. You can also try Michael greens suggestion of loosening the transformer screws. Try that first.
charles
qdrone
Reply #7 on:
29 May 2024, 04:00 pm »
VPI Magic Brick placed over the transformer on the outer chassis.
Last Edit: 29 May 2024, 05:02 pm by qdrone
Volunteer
Reply #8 on:
29 May 2024, 04:02 pm »
RF-Parts usually have rubber gromets that may fit this use.
Tam Lin
Reply #9 on:
29 May 2024, 07:45 pm »
How about these?
https://www.keyelco.com/userAssets/file/M65p133.pdf
I have a few left over from a long ago project. They are similar to Keystone #773. If you PM me your address I'll mail you some. How many do you need?
rockadanny
Reply #10 on:
30 May 2024, 04:52 pm »
Thank you! I found a small thin piece of sorbothane and slid it under. Improvement!
Thank you all!
andyr
Reply #11 on:
19 Jun 2024, 02:29 am »
I use a pad of 1/4" (6mm) Sorbothane under each power transformer that I need to use in a build.
John Tulett
Fascinated by vintage audio equipment
Reply #12 on:
19 Jul 2024, 08:44 am »
Pleased a successful result has been achieved, just to share my experience isolating transformer vibration / hum noise in my vintage Acoustat electrostatic speakers.
While I achieved some success with grommet mounting and anti-vibration sheeting, by far the most effective solution was found by replacing the bias transformer mounting hardware with anti-vibration threaded studs.
Please see, "
Acoustat Interface MK-121-2 - Minimizing the Bias Transformer Hum Noise
https://www.diyaudio.com/community/threads/acoustat-interface-mk-121-2-minimizing-the-bias-transformer-hum-noise.412612
With the Acoustat interface the bias transformer is mounted vertically to the chassis side, nevertheless, hope this solution may be helpful.
Thank you.
The Lab
sts9fan
