How to Use IC's in a Point-to-Point build?
0 Members and 1 Guest are viewing this topic. Read 2487 times.
Ericus Rex
« on: 27 May 2024, 04:44 pm »
Considering building a P2P tube preamp that uses a 2 x 7 pin linear voltage reg IC in the power supply. Is there a more graceful approach to attaching the wires to the legs than direct soldering?  Something like break-out boards or through-hole sockets? I don't see them available but I'm honestly not even sure what to call them.
Thanks for your help!!!
Doublej
Re: How to Use IC's in a Point-to-Point build?
« Reply #1 on: 27 May 2024, 05:02 pm »
Try searching for images of IC Socket. It might be what you want.
« Reply #2 on: 27 May 2024, 06:15 pm »
Interesting project. What is your shematic?
If you dont need much gain consider an EE Minimax clone :thumb:
http://www.glowinthedarkaudio.com/minimax.html
« Last Edit: 27 May 2024, 08:05 pm by FullRangeMan »
JohnR
« Reply #4 on: 28 May 2024, 04:43 am »
Ericus Rex
« Reply #5 on: 30 May 2024, 12:29 am »
Thanks Everyone!
I found this socket that I think will work perfectly if I through-hole mount it onto an insulated board and bend the legs into solder eyelets.
https://www.mouser.com/ProductDetail/575-1234731441001000
You guys are the bestest!
« Reply #6 on: 30 May 2024, 12:46 am »
When you buy the chip ask for the socket, the store that sell you the chip may have the socket in stock.
