Stories of being converted to Class D?
0 Members and 3 Guests are viewing this topic. Read 13849 times.
ethirolle
« on: 20 May 2024, 10:30 pm »
I am fascinated by the rise of "audiophile" Class D amps, and the increasing respect they get from reviewers and listeners. If you have been "converted" to Class D, I would be curious to hear what amp converted you, and what your journey was before you arrived at Class D. Did you come from Class A/B solid state, or pure Class A, or even tubes? What convinced you that Class D was right for you?
I am most interested in stories where Class D just sounded so good that you no longer felt you were compromising by listening only or primarily to a Class D amp.
My story first: I have been a Class A/B solid state amp listener for most of my life, starting with high-current HK integrated amp from the 1980s, and later with an Anthem receiver (which I still think sounds fantastic), and most recently a beautiful Luxman L507-u integrated amp. I even dabbled in tube amps with a nice mid-priced SET amp (Tokyo Sound Valve 100/SE). But on a lark, I bought a used pair of Bel Canto Ref500M monoblocks, and later a Bel canto Pre3... and these have become the core of my primary listening system. I just find them to be as good as anything I have ever lived with: refined & balanced, powerful and liquid-sounding. What more can I ask for? The sense of sonic realism is startling when I first turn on a good recording.
Cheap Class D can sound lifeless and grey. But well-executed Class D can hang with the big boys! (Though I will admit that I have not spent much time with some of the BIG boys, like Pass Labs pure Class A solid state amps...)
Thanks in advance for your stories of how you arrived at Class D!
Eric
« Last Edit: 21 May 2024, 02:22 pm by ethirolle »
stylerb
Re: Stories of being converted to Class D?
« Reply #1 on: 21 May 2024, 02:06 am »
do the Bel Canto still use ICEpower modules? i dont know much about class D but would like to know the difference between ICEpower, NCORE and Eigentakt.
mresseguie
« Reply #2 on: 21 May 2024, 06:04 am »
Hi, Eric. Welcome to AC.
I've got both 300b tube mono amps and Class D amps in my 'corral'. The Class D amp is a Nuprime Evolution STA that I purchased a couple years ago. I typically use it in my main system during the hottest months.
I own a couple other Class D amps that I use in desktop (Nuprime's Omnia A300) or bedroom (IceEdge1200as2) applications. The IceEdge amps sound pretty good and are very powerful, but they lack the warmth of my Nuprime Evo STA amp.
Michael
« Last Edit: 21 May 2024, 04:04 pm by mresseguie »
Phil A
« Reply #3 on: 21 May 2024, 12:23 pm »
I've owned a few class D amps (and currently use one in the main system and another in a back-up system).  Prior to that, I've owned class A/AB amps (all the way to one which is still a current model and lists for $11k) for about 40 years.  I never envisioned getting a class D amp when I first heard them about a decade back.  While they had some nice qualities back then, it just didn't impress me as something I'd consider.  I first tried a stereo IcePower (probably around a half dozen years back) amp which I figured I'd end up using in a secondary system (where I had a class A/AB amp from a well known manufacturer) and I was shocked how much better the class D was (I used to think the secondary system shortcomings were the speakers).  I was even more shocked when it bested my $11k list amplifier (and that's not just my opinion as others heard it).  I think class D will get better when they start using discrete input stages vs. inexpensive op amps as the what the signal passes through first.  I think a lot of people just automatically dismiss them based on their pricing and based on some of the early models.
Early B.
« Reply #4 on: 21 May 2024, 12:48 pm »
Well-executed amps of all varieties are expensive. Good Class D amps are now on the same level as good Class A or A/B amps. If I were gonna buy a solid-state amp today, I'd seriously consider a Class D amp due to convenience (lower weight, etc.) and my budget would be several grand. Tubes are a different breed altogether and there's no comparison  -- either love 'em or leave 'em.
Zuman
« Reply #5 on: 21 May 2024, 01:29 pm »
There's Class D and there's Class D...
Most Class D amps are analog, but I had a NAD Masters Series M32 digital Class D integrated for many years. I thought it was great, until I switched in a Modwright KWH 225i amp, which is Class A/B with a tube front-end and a solid state output stage, operating in Class A for the first 25 watts.
It was the single-biggest sound quality improvement I've ever made to my system, providing a much greater sense of control and heft and a smoother, purer-sounding top end. I don't know whether it is because of the triodes, the extra 40 wpc, the analog signal path, or the A/B operating class.
That said, I'm also intrigued by some of the newest Class D designs, and I believe that there are still breakthroughs being made which will benefit all of us. Progress continues even in Class A with companies like WestminsterLab, whose compact 35-lb Class A monoblock is being embraced by many ultra-high end enthusiasts who normally stick with 100-lb + monsters.
These are exciting times, and I think that the key mindset is to be open to the future, not mired in the past.
cheesey
« Reply #6 on: 21 May 2024, 03:10 pm »
Used all sorts of amps over the years. Tried a Spectron Musician 3 and never looked back. Bruno Putzeys changed the game- his ncore and now Purifi have removed the amp from the intellectual debate. Been using a Hypex nc1200 for a few years now and have the new Purifi 9040 on order along with a ncx500 stereo amp. Will use the nc1200 and ncx500 on 4 subs and the new Purifi on a pair of Acoustat 6600's.
ethirolle
« Reply #7 on: 21 May 2024, 03:27 pm »
Thanks all for your comments so far!
@stylerb: the Bel Canto Ref500M use ICEpower modules, but I think Bel Canto switched to using Hypex Ncore with the Ref600M, and I believe (tho I could not confirm) that this has continued with their latest models (Ref601M & Ref501S).
I have not had the opportunity to hear these more recent models, but the reviews continue to be excellent, so I think I'd love someday to audition them and perhaps move up the chain.
Speaking of reviews... Herb Reichert's review of the Ref600M from a few years ago (https://www.stereophile.com/content/bel-canto-eone-ref600m-power-amplifier-herb-recihert-september-2017) correlates well to my experience with my Ref500M: startling sonic realism and a beautiful sense of space. Those two things go a long way for me.
I could not agree more  :D
If I can get my sonic yayas from these slivers of technology that weigh only 10-20 pounds, and use 80-90% less power while not heating up my room, then I salute all the engineers who have made this possible! I have both traditionalist and technologist in me: it makes me excited to see progress and innovation in amplifier design, but only if it serves the goal of dishing up beautiful music :-)
newzooreview
« Reply #8 on: 21 May 2024, 03:38 pm »
There are a few very well-done tests on Youtube. Alpha Audio uses a good format, combining bench measurements with very high-quality microphones and a panel of experienced listeners each with a different background. They typically record the full 2-hour listening session, and it's easy to discern differences in tonal balance, timbre, and detail with a pair of headphones. What they comment on is almost always apparent in the differences that can be heard in the recording.
One informative comparison was of ICEpower, Purifi, and the most recent Hypex (Nilai) Class D amps along with a Pass Labs XA250 (their reference). The contrast between Purifi and the Nilai is very interesting. The Purifi is detailed and punchy and the Nilai clearly portrays the harmonics in acoustic instruments and the timbre much more naturally. It's worth a watch: https://www.youtube.com/watch?v=NdZFAWe1Nxo
They also compare the Hypex Nilai (which they built from the DIY kit) to a Yamaha A S2200: https://www.youtube.com/watch?v=dkUgStoRzvs
And in their test of monitor speakers, they switch between the Pass Labs and Nilai with, again, audible differences. https://www.youtube.com/watch?v=U7sXOFirQKo
With their stereo Schoeps microphone setup, the recording easily allows for comparison even if it cannot capture the soundstaging perfectly.
Based on the GaN, ICEpower, and Tripath amps I've owned, along with the Alpha Audio comparisons and comments on this site, good Class D is on par with good Class A and A/B in many price ranges. In the cheap and cheerful price range it's generally better than Class A/B; in the mid to upper price range (say $500 to $5000) it's competitive and the choice depends on speakers and preferences, and above $5000 there are probably more excellent non-Class D options than Class D options. A generalization, obviously.
However, ICEpower is not very good, and some cheaper Class D has load-dependent frequency response (like the cheap little WiiM Amp I've owned or the measurements of the Fosi amps).
Good Class D, even the off-the-shelf Purifi and Hypex modules and power supplies, has a flat frequency response regardless of speaker impedance.
Early B.
« Reply #9 on: 21 May 2024, 04:00 pm »
For seriously good Class D sound, you'll still need a beefy power supply. The same is true with any other type of amp. However, we're no longer talking about 100+ lb. solid-state monoblocks. Class D amps weighing only a few pounds can sound very good, of course, but they probably won't be top-of-the-line offerings. A good example is AGD's amplifier options which get progressively heavier as you move up the line. Whereas the Audion weighs a mere 6.5 lbs., their top-shelf Solo model is a monoblock weighing 45 lbs., with most of the weight attributed to a large transformer.
DannyBadorine
« Reply #10 on: 21 May 2024, 04:06 pm »
I have been designing and making my own speakers for years and recently discovered how poorly my tube amp drives them.  It changes the frequency response by as much as 3db on speakers that have easy impedance loads.  The Class A/B and Class D amps measure the same.  This much of a frequency response change is a total nightmare and easy to hear.  The advent of new Class D amplifiers shows that they can outperform everything else if you want to reproduce your music accurately.  There are some Class A/B amplifiers that can keep up.  Class D is also much cheaper and more efficient so you can have a ton of wattage to drive inefficient speakers, which is a major advantage.  I always wanted to say that Class D didn't sound as good, but really it just sounds more accurate and colors everything much less.  So when I thought it didn't sound as good I was actually hearing the problems in recordings and mixes.  When you deliver more accurate sound, it doesn't always sound better immediately.  But I learned that I do want it to be accurate and I enjoy that much more.
djpk
« Reply #11 on: 21 May 2024, 04:06 pm »
I've always had Class A/B amps, but had enough curiosity to purchase a new Mivera Audio Class D amp. Switching between my Audio by Van Alstine FET Valve 600R and the Mivera amp in the same system with Odyssey Audio Kismet speakers, I could not tell any difference in performance. I'm happy with both amps.
Early B.
« Reply #12 on: 21 May 2024, 04:37 pm »
Yeah, this is a good explanation of Class D sound. It's exceedingly accurate and some audiophiles think it's too accurate. We rarely equate live music with being "accurate." Far from it. I'm not condemning Class D, just point out preferences. I have an audiophile buddy who once said to me, "I like my music with a little bit of mud in it."  I had a Purifi amp and I loved it, but then I traded it out for a good tube amp and it was game over.
ethirolle
« Reply #13 on: 21 May 2024, 07:07 pm »
I am 100% on-board with this approach to choosing your audio gear. To paraphrase Duke Ellington: if it sounds good (to you), then it is good.
I don't explicitly seek "accuracy", but I think I seek something like "transparency", or something like timbre + microdynamics & soundstage that (for me) creates a spooky sense of almost being there in the space with the musicians. And as I go along in this hobby and can afford slightly more expensive gear, I find I can now get other thing that also add to the experience, like tighter bass control and real dynamic slam. I get all of this from my Bel Canto Class D amps, so I'm a happy camper :-)
I.Greyhound Fan
« Reply #14 on: 21 May 2024, 07:12 pm »
I like class D amps.  I have heard many higher end D amps and even own some cheap chip amps. Many have great air, transparency and deep fast well controlled bass.  My issue is that some Class D amps weigh about 4-5 pounds with little electronics inside and companies are charging thousands of dollars. I get it, they need to pay for R&D and need to make a profit.  I still prefer my brute amp a Pass X250 despite it weighing 105lbs and it becomes a space heater after 1 to 2 hours of playing.
As I say this, I will probably eventually give my amp to my son and move on to a Class D amp sometime in the next few years as I get older.  Or I just may buy a Pass X250.5 or 250.8. :D
HAL
« Reply #15 on: 21 May 2024, 07:17 pm »
I switched from Pass Labs Aleph 2 monoblocks to Orchard Audio Starkrimson 150W monoblocks.  I have no regrets at all.  They sound great!
Photon46
« Reply #16 on: 22 May 2024, 11:56 am »
I wouldn't say I'm "converted" but I give them equal respect for their particular virtues when their design and manufacturing quality is well executed. I'm using a pair of PS Audio's hybrid M1200 monoblock amps in my second system with KEF R7 Metas at present. Prior to that, I was using a PS Audio BHK250 & Aloia 13.01 class A/B amps. I've also used the PSA M1200s with very revealing Tidal Piano Cera speakers in my other system to good effect. The ability to fine tune their sound by changing 12au7 input tubes is great. All the professional reviews I've read stuck with the stock tubes which really didn't fully explore their ultimate potential. I also have and use a DecWare Zen Tori II and Luxman M700 amps as well. I traded the BHK250 for the M1200s directly with PS Audio.
kmmd
    • Systems
« Reply #17 on: 22 May 2024, 04:45 pm »
Class D amps have always interested me.  Reading threads on the other forum grabbed my attention and having Class D sliding bias Class A amps interests me even more.  That seems similar in theory as my CODA No 16 but at less than half the weight and without the heat of my Pass Labs X250.8.  I have new 200 lb speakers on the way, so I’ve been considering a pair of monoblocks to drive them.  It’s been a very busy 8 months for my system, so it’ll be a little while before I can purchase a new pair of amps.  The good thing is that I’ll be able to listen to the WestminsterLab REI’s bridged and possibly AGD’s at The Show in Costa Mesa in a few weeks.  Any one else going?
Addendum:
I just got word from my dealer that my YG Acoustics Hailey 3’s have left Arvada, CO and on the way to me.  Yay!
« Last Edit: 22 May 2024, 06:18 pm by kmmd »
I.Greyhound Fan
« Reply #18 on: 22 May 2024, 08:06 pm »
Addendum:
Why consider a Class D amp when you have that wonderful 250.8?  I would be hard to beat that Pass amp with Class D.  So far I have not heard a Class D amp that compares to the 250.8.  Pass amps do not come up in the used market very often which in itself is telling.  I cant say that for most amps.
kmmd
    • Systems
« Reply #19 on: 22 May 2024, 08:39 pm »
Larry, the X250.8 is a fantastic amp for sure.  I’ve been very happy with it and can’t let it go for now.  I purchased it from Mark at Reno Hifi btw.  He was very helpful and hope he’s enjoying retirement.  However once you get a class A amp into your system, it’s an entirely different experience.  My CODA No 16 is more transparent, neutral and has a greater sense of space, air, separation and soundstage.  It is very controlled and also has a vice grip on bass.  My new Hailey’s are full range, so I’ll see what happens when using the CODA.  Reading about the Rei’s on What’s Best has me wanting to audition it.
Hope you’re doing well.
Ken
