New member intro!! 👋
0 Members and 1 Guest are viewing this topic. Read 547 times.
Arfaei
« on: 16 May 2024, 03:05 pm »
Hi I am Ardi
I am starting my audio journey
I have two separate setups with HS8s and HS5s for streaming and Records hooked up to Schitt DACs but I am ready to learn more and plan my next system, big beginner here so I love to get pointed to where is best to start learning more 🙏🏽
Phil A
Re: New member intro!! 👋
« Reply #1 on: 16 May 2024, 04:25 pm »
Welcome to AC!
« Reply #2 on: 16 May 2024, 09:21 pm »
Welcome to AC  :thumb:
If you have a hi sensitivity speaker as 100dB and bening impedance curve there is no much things to upgrade IMO, maybe inside the enclosure if you are picky as myself. Today audiophiles can take advantage from inexpensive and transparent powerful Class D or GaN-FET amps and recently with Lii Audio, also take vantage from inexpensive big cones full range drivers, this will save a lot of money hence no crossover and no enclosure need.
This is a inexpensive DIY project from an AC member, it have only four(4) parts: Eminence Alpha15A + 4.7mH + Visaton B200 and a MDF baffle.
Other option are the Lii Audio F15 FR driver $399/pair, not each.
Here Decware OB with the Lii Audio F15 driver:
If one have a woodworker is possible try the Lii Audio F15($399/Pair, pair not each) 97dB/8Ω and benign impedance curve suited to OB or Bass Reflex box or the F18($540/pair), no Crossover, no Tweeter beaming, no Phase rotation, no driver sensitivity loss, no Harmonics loss, no Retail price.
http://www.glowinthedarkaudio.com/lii-audio-f18.html
My personal choice is the Lii F18 in Single Driver configuration, but if you make question of wanting a 2-Way speaker you may want a bigger woofer than the Alpha15A, so there are W18 inches and W21 inches from Lii Audio, personally I dont like these two VCs woofers, they are hard to drive with a small tube amp.
https://www.lii-audio.com/product/w-18/
https://www.lii-audio.com/product/w21/
Please note some Circles of interest you may like>
The Fullrange Driver Circle:
https://www.audiocircle.com/index.php?board=128.0
The Open Baffle Circle:
https://www.audiocircle.com/index.php?board=90.0
The Tube Amps Circle>
https://www.audiocircle.com/index.php?board=144.0
The Vinyl Circle::
https://www.audiocircle.com/index.php?board=32.0
« Reply #3 on: 17 May 2024, 12:33 am »
Greetings & Welcome to AC Ardi   :thumb:
« Reply #4 on: 17 May 2024, 12:03 pm »
Best speakers are active (used by recording studios).  PMC are some of the best.  Kii Three are top of the line too.
