EverSolo DMP A6 streamer ( power supply )
0 Members and 1 Guest are viewing this topic. Read 883 times.
Nuforce_70
« on: 2 May 2024, 01:54 am »
I have a question about SMPS power supply of EverSolo DMP A6 streamer - SMPS power supplies are famous for contaminating power lines with noise and harmonics. I am NOT talking about the quality of power that the source delivers to the internal electronics of the DMP A6, because I am sure it is very good. I'm talking about the noise and harmonics that I could inject into my power line, so the question would be: is the DMP A6 source filtered enough to not inject any harmonics into my power line? . This question is because I will soon buy a DMP A6 and connect it to the output of my isolation transformer, which has a power amplifier and a preamplifier connected, both components are 100% analog and use 100% linear sources. This isolation transformer delivers very clean energy. I would not like that energy to be contaminated with noise and/or harmonics. Thank you for your help !!
Re: EverSolo DMP A6 streamer ( power supply )
« Reply #1 on: 2 May 2024, 02:38 am »
You could try an PS Audio Noise Harvester.
https://www.psaudio.com/products/noise-harvester
Jon L
« Reply #2 on: 2 May 2024, 03:47 pm »
From what I gather, the Eversolo to buy is the DMP A6 Master Edition and install the internal Beatnik linear PS.
https://www.youtube.com/watch?app=desktop&v=ODHerC-KzFY
