IDA-16 Case Removal help
0 Members and 1 Guest are viewing this topic. Read 2698 times.
newaudio11
« on: 29 Apr 2024, 05:10 am »
I posted that my IDA-16 was leaking but before checking on possible repair, I would like to see which board is causing the issue
and clean up the inside.
I found a post from 2018 where someone showed the case is opened from the bottom.
However, I can't get any Phillips head to catch in here.  I need to work from underneath as I don't want the fluid to spread around.
The screw is fairly small but the slots are wide.  It gives me the impression of some type of tamper-proof screw that will strip easily.
But that might just be me after researching screw types for a while.  Any help is appreciated.  thanks
rustydoglim
    • www.nuprimeaudio.com
Re: IDA-16 Case Removal help
« Reply #1 on: 29 Apr 2024, 05:56 pm »
The factory support staff should be able to help you: https://b2b.nuprimeaudio.com/helpdesk/
newaudio11
« Reply #2 on: 29 Apr 2024, 09:47 pm »
Thanks, I opened a ticket with the helpdesk.
