SOLD - BEL 1001 MkV Amplifier - Latest Revision MONO or Stereo NEEDS WORK!
0 Members and 1 Guest are viewing this topic. Read 1764 times.
undertow
SOLD
PRICE - $400.00
Okay so this is for a BEL 1001 MkV latest greatest version of this amp made sometime between 2007 and 2009.
The Chassis is in near perfect condition no real marks can be seen so excellent. Power supply is massive and working.
HOWEVER, this unit was running perfect for about 15 years, and early April decided to start making noise.
It turns on an operates, but after a couple minuets will start making static noise and popping thru the speakers.
Not sure if it is both channels or just one?
Anyway, it is for sale here SUPER cheap because in perfect operating condition would be worth $1900.00 to $2600 depending on cosmetic condition and as stated above it is excellent cosmetics.
You get it as is. I am sure the parts alone are worth more including the Chassis than is being sold here.
If your a tech or know somebody probably needs a new set of matched Transistors or whatever is wrong with it for $100 or something, and your in the jackpot.
_______________________________________ _______________________________________ _______________________________________ _______________
BEL of course shut down in 2009 with the death of the founder.
But these amps are very desirable still and easily best any solid state out there.
This BEL MK V Amplifier Specifications: Coaxial RCA Inputs 1 pair L&R
Stereo/Mono switch, multiple-way solid copper binding posts, 6A/120V fuse, and detachable IEC power cord.
OUTPUT: Full Bridge Mono Configuration (Internally Balanced Output) 200 watts/8 ohms, 400 watts/4 ohms. Half Bridge Stereo Configuration 50 watts/8 ohms per channel, 100 watts/4 ohms per channel, 200 watts/2 ohms per channel.
Bandwidth: 5 Hz to 200 kHz.
Polarity: Non-Inverting.
Gain Mono: 26 dB (2V = 200W/8).
Gain Stereo: 26 dB (1V = 50W/8).
Optimum Preamplifier Headroom: 12 dB. Input Impedance 27 kohm.
Power Requirement 50/60Hz with 100-120V.
Quiescent Power Consumption: 200 VA cold, 100 VA warm.
Maximum Power Consumption: 700 VA.
Dimensions (WxDxH) & Weight 17.2 x 12.8 x 7.2 inches & 29 lbs. 437 x 325 x 183 mm & 13.2 kg.
MSRP $3895. Chassis, panels and extrusions are all aluminum alloy.
BEL products are manufactured entirely in the USA and Handmade by Richard Brown.
« Last Edit: 15 Apr 2024, 10:35 pm by undertow »
Vectorone
Hello Undertow
I would like to buy your amp. ( Actually a friend of mine, who isnt on Audio Circle.)
Please let me know the  details
Thank you.
Bruce
undertow
Sorry SOLD
« Last Edit: 15 Apr 2024, 10:34 pm by undertow »
