MANUAL for VMPS SuperTower III's WANTED
0 Members and 1 Guest are viewing this topic. Read 2400 times.
spitfun
« on: 7 Apr 2024, 01:52 pm »
I have a pair of ST III's and am looking for a manual-anybody have any leads on one? I am going to biamp mine and wanted to know how the load changes in biamp mode Thanks Rich
Avoosl
Re: MANUAL for VMPS SuperTower III's WANTED
« Reply #1 on: 8 Apr 2024, 12:11 pm »
Rich,
      When mine arrived from Brian sometime around 1991, there was no manual. In case yours don't have the sticker on the back, here's what the relevant portion of mine looks like:
"Impedance 8 ohms(Bass/mid section 8 ohms, treble section 8 ohms in biamp use)."
Bob
davidc1
« Reply #2 on: 7 May 2024, 07:31 pm »
HI Rich, I have the same speakers and a pair of Supertowers.
Just to manage expectations, there isn't a detailed 'manual' for these speakers. You'll find a simple piece of paper glued to the back, which primarily covers bass damping adjustment and speaker placement suggestions.
Regarding the bi-amping...well, it's not gonna gain you anything. The "problem" is that, because of the quasi-second order crossover along with the series and parallel wiring of the woofers, the biamp part of the crossover is between the mids and the tweeter, not between the woofers and the mids. Therefore, you'll have one amp running at about 90% of the power and the other at about 10%. If you are looking to gain some overall power, you are better off bridging your amps instead if you can.
