Question about Pioneer 1014/1015
0 Members and 1 Guest are viewing this topic. Read 1242 times.
awm
« on: 9 May 2005, 09:04 am »
Does anyone out there know if either of these will drive a 3 ohm load?
Andy
Al Garay
« Reply #1 on: 9 May 2005, 02:17 pm »
Which one of your speakers is 3ohm? I thought you were giving away the M8 Mkiv.
bubba966
« Reply #2 on: 9 May 2005, 04:23 pm »
I've seen a 1014 run 4 ohm 87 dB (@ 1 watt / 1 meter) speakers just fine. The 1015 has the same amp section as the 1014, so it should perform the same.
I'd guess it'd handle 3 ohm speakers ok, but I can't say for sure as I've not actually tried it.
awm
« Reply #3 on: 9 May 2005, 06:00 pm »
Thanks, bubba!  That helps a lot.  Looks like I'll be getting one of these in the near future.
Al, I am giving the M8a's away.  It'd be for another project.
Andy
awm
« Reply #4 on: 9 May 2005, 09:48 pm »
One more question re the preouts -- can they be run simultaneously, i.e. with no HT processing time delay?  I want to try to run an active crossover to a three-way and would need six channels of amplification, which this will provide.  But, I need them all run simultaneously...
Andy
