Crossover point for NX-Series
0 Members and 1 Guest are viewing this topic. Read 1884 times.
BrandonB
« on: 28 Mar 2024, 08:51 pm »
If you have an NX-Series speaker where are you crossing it over to the subwoofer and are you using a HI-pass filter?  Just checking out what everyone is doing.
nlitworld
Re: Crossover point for NX-Series
« Reply #1 on: 29 Mar 2024, 02:06 pm »
Hi Brandon,
I currently am high passing my nx-studios and am messing around with the crossover point. I accidentally undervalued what I needed so right now they're crossing a little over 100hz to my stereo subs. I'll be adjusting that down to hopefully cross at 75 or so. In my small room the studios play to about 40-50hz when left full range even though specs say they only play to 70. Hope that helps!
-Lloyd
SRP SRP
« Reply #2 on: 30 Mar 2024, 05:08 am »
I’m using a sublime acoustic active crossover. 80 Hz.
NX studios and a couple of rythmik subs
Nickando
« Reply #3 on: 30 Mar 2024, 09:45 am »
Are they the sealed or open baffle subs? If sealed, how do they sound?
SRP SRP
« Reply #4 on: 30 Mar 2024, 12:18 pm »
One is sealed, the other ported - with the port plugged. They sound ok, but I’m upgrading to a pair of double troubles soon. Just finished the flat packs.
Nickando
« Reply #5 on: 31 Mar 2024, 10:06 am »
Nice!
