Advice on room set up
0 Members and 1 Guest are viewing this topic. Read 845 times.
listenermark
« on: 21 Mar 2024, 03:59 pm »
Looking for advice on setting up my room.  It's 15 x 17 with a pitched ceiling (see image below.) The pitch runs along the long side of the room.
At the moment, I can set it up any way I wish.  The only furniture will be my listening chair, some crates of records, and probably a bookshelf. Floor is covered in throw rugs and the window bank has light curtains. Lots of art on the wall and some homemade diffusion panels. the room will only be used for listening to two channel music.
I will be using bookshelf speakers (either rear ported LS Encores or front ported Elac debut reference) on stands along with two sealed 12" subs. I listen at moderate volumes, generally mid to upper 70's.
Early B.
Re: Advice on room set up
« Reply #1 on: 21 Mar 2024, 05:07 pm »
Consider setting up the speakers catercorner in the top right portion of the room.
