Speaker Snap Banana Plugs
0 Members and 1 Guest are viewing this topic. Read 1887 times.
xsb7244
« on: 11 Mar 2024, 05:45 am »
Re: Speaker Snap Banana Plugs
« Reply #1 on: 11 Mar 2024, 06:43 am »
In the 1970s all low cost amps came with this connector system standard, now 50 years later they are releasing this thing Patent Pending as a advantage.
Letitroll98
  • Too loud is just right
« Reply #2 on: 11 Mar 2024, 11:30 am »
Hilariously cheap on both examples.
Peter J
  • Hmmmm
« Reply #3 on: 11 Mar 2024, 05:17 pm »
To my eye, those are distinctly different connectors. The linked device is using a novel wire connection method to a conventional banana plug. The other using a spring-loaded pseudo-guillotine connection  designed for bare, or perhaps tinned, wire.
The SpeakerSnap would appear to borrow heavily from WAGO idea of wire connection, which in most jurisdictions is electrical code approved. Doesn't necessarily make it good for audio signal connections but is not without precedent.
 https://www.wago.com/us/c/wire-splicing-connectors
