Cable Risers
0 Members and 1 Guest are viewing this topic. Read 3155 times.
RonP
Cable Risers
« on: 9 Mar 2024, 02:51 am »
Found out about these over on the DecWare Forums.
https://www.lirecordcare.com/shop-1
I got the 10 pack: https://www.lirecordcare.com/product-page/suspension-cable-elevators-set-of-10
They are quite good!
I need another 10.
Markwatkiss
Re: Cable Risers
« Reply #1 on: 9 Mar 2024, 03:29 am »
Toilet paper rolls work great.
Re: Cable Risers
« Reply #2 on: 9 Mar 2024, 04:10 am »
I like cable raisers they elevate the performance.
« Last Edit: 9 Mar 2024, 06:45 am by FullRangeMan »
KTS
Re: Cable Risers
« Reply #3 on: 9 Mar 2024, 11:38 am »
Wow, very reasonable prices thank you for sharing. I used rebar trees with fancy wooden close pins.
mav52
Re: Cable Risers
« Reply #4 on: 9 Mar 2024, 01:25 pm »
Empty Toilet paper rolls work good as well  :D
Cheap to, paint to match  :thumb:
scp2
Re: Cable Risers
« Reply #5 on: 9 Mar 2024, 03:18 pm »
Havent tried these yet...but am going to. Rebar risers and stretch a rubber band across. Not sure of size..just read abot on another forum.
https://www.homedepot.com/p/Grip-Rite-2-1-4-in-Rebar-High-Chair-20-Piece-IHCP21420R/202090708
S Clark
Re: Cable Risers
« Reply #6 on: 9 Mar 2024, 03:34 pm »
Seriously, what is this evil effect that carpet has on signals in cables?   And what is the audible effect?
RonP
Re: Cable Risers
« Reply #7 on: 9 Mar 2024, 03:56 pm »
Oh that's interesting!
newzooreview
Re: Cable Risers
« Reply #8 on: 9 Mar 2024, 04:31 pm »
Static electricity and the carpet acting as a dielectric.
We've all seen the potential for static charges to build up on a carpet. You end up with a DC charge of variable strength along the length of the cable lying in the carpet.
Carpet also acts as a dielectric. As the signal propagates down the cable, the radial component interacts with the dielectric covering over the wire. Carpeting adds to, or extends the dielectric, changing the designed behavior of the cable.
Whether or not this affects a specific cable, carpet, system, and listener combination isn't going to be knowable without listening. And many will cling to the pseudoscience that it doesn't matter and it's all in the listener's head.
mlundy57
Re: Cable Risers
« Reply #9 on: 9 Mar 2024, 04:39 pm »
A couple other reasons for cable risers are to keep the cables organized and keep signal cables away from power cables.
Speedskater
  • Kevin
Re: Cable Risers
« Reply #10 on: 9 Mar 2024, 04:53 pm »
Only two reasons that I can think of:
1] To make it easier for the housekeeping staff to vacuum.
2] To prevent the cable label dye from staining the white carpet.
KTS
Re: Cable Risers
« Reply #11 on: 9 Mar 2024, 06:00 pm »
My speaker wires cross some other signal wires, was the primary reason, I do not know if it makes a difference, but I gave it a shot. It was a fun DIY project that kept my brain going while I was waiting to do other projects. It is on carpet, but again I did not A/B as I do not have golden ears.
Kelly,
Re: Cable Risers
« Reply #12 on: 9 Mar 2024, 08:04 pm »
Home Depot dont allow access to its site from outside US.
Access Denied
You don't have permission to access "http://www.homedepot.com/p/Grip-Rite-2-1-4-in-Rebar-High-Chair-20-Piece-IHCP21420R/202090708" on this server.
Reference #18.59c41002.1710014743.1b35afac
Bob2
Re: Cable Risers
« Reply #13 on: 9 Mar 2024, 09:28 pm »
One would think that with all of the shielding and insulation of wires inside a cable the size of a garden hose that "cable lifters" would be superfluous. Seems you see a lot of "cable lifters" for sale in the used category. :scratch:
Re: Cable Risers
« Reply #14 on: 9 Mar 2024, 09:36 pm »
Years ago I used a dozen of porcelain coffee mugs to raise some cables, I was unable to listen any difference YMMV.
Doublej
Re: Cable Risers
« Reply #15 on: 10 Mar 2024, 12:58 am »
Access Denied
Try searching for it. Here's an image to the product.
https://www.audiocircle.com/index.php?action=gallery;area=browse;image=262191
Re: Cable Risers
« Reply #16 on: 10 Mar 2024, 02:16 am »
Thankyou I just used VPN.
djpk
Re: Cable Risers
« Reply #17 on: 10 Mar 2024, 02:34 am »
I use inverted 16 ounce paper cups. Works fine for me.
ketchup
Re: Cable Risers
« Reply #18 on: 10 Mar 2024, 03:04 am »
I have been 3D printing mine in whatever height or configuration needed.  This one has a pivoting top piece to match the angle of the cable since these particular cables are very stiff and don't like being told what to do.
Early B.
Re: Cable Risers
« Reply #19 on: 10 Mar 2024, 04:18 am »
No point debating the sonic merits of cable risers. They look cool. 'Nuf said.
